help on 72 maverick stereo
Discussion in 'Audio' started by nysean91, Jun 15, 2013.
  1. nysean91
    nysean91 Member
    1972 ford maverick
    Hey so ive had a 72 maverick for about 6 months nowbso im tryng to put a newer stereo dock in it and put some subs in. My issue is what I need adapter wise so I can use a more up to date radio .ive looked on amazon and saw something but I dont wanna buy the wrng thing. Also removng the orginal am radio thats in it. Ive tookin out the bolts but it doesnt seem to pull out easy,I. Left it cuz I dnt wanna break anything so muly question is after I take off the initial bolts is that all thats holding it secure and should I jus wiggle and work it out
  2. nysean91
    nysean91 Member
    1972 ford maverick
    Or do I jus have to wire the factory car wires into the head units harness
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    There is a stud on the back of the stock radio. Take the nut off the back and the 4 screws that hold in the mount under the front lip of the mounting bracket. Then it should slide right out. then you can use the slide in mounting plate for the new head unit as a template to cut out the mount. then mount it back in the car in the stock location.
    Hope that helps a bit.
  4. nysean91
    nysean91 Member
    1972 ford maverick
    Awesome thanks will do once sun comes up here in fl lol. Any idea on the wiring cuz I boight a cd p layer fron a pawn shop but has no woring harness on it do you have any siggestions what I should get
  5. Bryant
    you dont need any wiring adaptors. these cars only had a power and lighting wire and the speaker wires for the speaker in the dash.
    you can use the power wire for the switched wire on a modern stereo and the lighting wire for the dimming feature on some stereos. you will need to add the battery power wire and all the speaker wires.
  6. nysean91
    nysean91 Member
    1972 ford maverick
    The battery would get connected where? Im new to the classic car world and there stereos
  7. Craig Selvey
    You need to use the wiring harness that came with the radio, and put all new wires in for the speakers. This will not be a "plug and play" type of thing like it is with new cars.
    If you have the radio from a pawn shop and you did not get the wiring diagram, it may be difficult to figure out what wires go where. You may be able to Google the radio name brand and model and find a wiring diagram online.
    Good Luck.
  8. catesmiester
    catesmiester Member
    ohio
    1972 Ford Maverick
    For the power you can just run a wire to the fuse block
  9. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    you would want to wire it so when you turn off stereo/cd player it'll resume and not restart every time you turn on engine.
    i'd put an inline fuse behind the CD player also.
    you can get brand new CD players with an iPod/Android input and sometimes also with Bluetooth to stream Pandora or w/e for around 100 if the pawn shop HU doesn't work out.
    you also need a good ground that'll rear 12volts
    the black wire is typically the ground wire
    the power/ignition wire will be either red or yellow depending on brand of headunit
  10. CaptainComet
    hello again,
    To carry on with the answer I gave to your other post in the "other" section ...
    This website is tops for info for car stereo and related stuff ...
    http://www.the12volt.com/
    It can help you decipher what you bought. They post charts for most audio gear out there.
    To power your stereo, I would use the factory keyed power lead, so that it turns on and off with the ignition. It is likely that there is a "constant" lead, also. That maintains your clock and radio presets. A great place to tap power for that is the cigarette lighter wire, since it is hot 24/7.
