Help on Hood Hinges
Discussion in 'Technical' started by kukm66, Jan 16, 2008.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    Did any of the later model Mavericks or Comets have hood hinges with springs so as to eliminate the prop rod? Has anyone tried to hook up any springs by modifying the arms? On the early Falcons and Comets, Ford used the same arm configuration but simply hooked up springs to the them by doing some minor mods. Other than that, they were the same.
  2. newtoford
    newtoford Member
    New Castle Delaware
    they never came on these cars but im sure you could rig something up
    the hood does seem a little flimsey though to have allthe weight supported on the bottom. the prop rod holts it closer to the top which probably helps it from warping
