Help on taking rear seat off of 74 comet
Discussion in 'General Maverick/Comet' started by Theo1250, May 25, 2008.
  1. Theo1250
    Theo1250 Member
    Leander Texas
    1974 Comet
    Hello Guys,
    I
    m trying to take out the rear seat of a 1974 Comet 2 door, but I hanen't been able to do it... I don't see any screws or anything even looking trough the trunk... any hints??
    Thanks!
    Theo.:16suspect
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The bottom part of the seat must be removed first. It is a unique experience the first time you remove one. After you do it once it is easy.
    You have to push down and while holding down you push the whole seat towards the back of the car to release it from the catch. Then you can left up and remove it. The upper part of the rear seat is held in with 2 bolts that you will see after you remove the bottom.
  3. Theo1250
    Theo1250 Member
    Leander Texas
    1974 Comet
    Thanks!! I'll try that right now.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Sometimes it helps to bump the front of the seat cushion while holding down on it from the top, if it has never been out before they tend to stick to the mounting brackets....
