Help RPM's not dropping back to idle! Whats going on?
Discussion in 'Technical' started by David74maverick, Mar 25, 2010.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Lately when I release the throttle the rpms like to linger around 2000 for awhile before slowly going down to idle. My car has a manual in it so when I change gears it pulls the idle down or where ever it needs to be so I can still drive it but it's still a issue that needs to be resulved. This happened before and all I did was spray down all the external linkages on the carburator (edelbrock 1405) as well as the throttle cable with carb cleaner and that helped for a while but now it's back... I've been running this carb for along time with no problems than this happened first about 4 months ago and now today. Any ideas what could be causing this? My return spring is strong enough and it's NOT fully compressed at idle so theres constant tension on it. I plan on just spraying more carb cleaner on it and hope for the best but some input would be appreciated. thank you.
  2. Centerline
    Centerline Member
    Washington State
    1971 Ford Maverick Grabber
    Push your choke into the dash. :D
    Sounds like your carb needs a good cleaning if last time you just sprayed it down with cleaner it helped. Makes me think that it's sticky on the pivots, and the spring isn't strong enough to quickly overcome it. If you put a tighter spring on it and it solves the problem, that was it.
  3. Shinysideup
    Shinysideup Chillin the most
    town
    car
    Seroiusly consider rebuilding the carb.
  4. David74maverick
    Arizona
    Is that about the only thing it could be? could vacuum be a posible culprit? and yes the choke is all the way in... all it does is bog the thing down anyway if I pull it more than closing the butterflys...
  5. 71gold
    the carb. cleaner is just that...it cleans.
    i would suggest a...lub. spray... after the cleaning...:thumbs2:
  6. bmcdaniel
    bmcdaniel Senile Member
    Had a similar problem once. The bracket on the inside firewall that holds the gas pedal rod was binding and needed lubed. Maybe you got one of those Toyota pedals? :rolleyes:
  7. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Mine does the same thing.
    I will get a rebuild kit for it soon.
  8. Mavman72
    Make sure the secondary throttle blades are closeing (may be stuck partially open)
  9. don graham
    Make sure your return spring is strong enough.:)
  10. mitch christens
    mitch christens Member
    Marion,iowa
    75 maverick, 2006 jaguar x type, 2004 ford f-150 super cab,
    Lube after cleaning!
  11. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    I second that.
  12. Mavaholic
    Disconnect the throttle cable and try reving the carb. If it still has a problem, the problem is in the carb. If not, its your cable.
  13. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Lube it but also check the gasket between the carb and spacer and or intake. The butterflies can stick on those. Might only happen after the secondaries have been opened
    clint
  14. JDHill
    JDHill Member
    San Diego, Calif.
    Maverick Grabber 1971
    While running it put hand over the carb to see if it will die, f not than you have a vacuum leak which raises idle and will hold it there. What type of chock pull off do you have? If heat riser type could be the spring is weak and not pulling chock all the way off. May have the same problem if it's vacuum pulled. :hmmm: just a thought may have weak spring. :cry:
  15. PaulS
    The engine compartment is a dirty, dusty place and if you lube the linkage with spray lube just make sure it is a dry lube. If you oil the linkage or cable all that dust and dirt will stick to it and either cause wear or sticking.
    I was always taught that you NEVER lube linkage unless you use wax or dry graphite , silicone lube.
