Help with 200 CID - 1BBL
Discussion in 'Technical' started by allen nicely, Nov 15, 2011.
  1. allen nicely
    allen nicely Member
    La Grande Oregon
    I have a 71&74 maverick
    okay i put a new 200 six in my maverick the other month but i am having trouble getting it to run right, it idles okay but when i give it a little gas, she dies,I don't know if the valves are off,i set them to top dead center.hoping it's any easy fix
    do you think you could at least point me in the right direction? by the way it has the 1bbl carb thought about going to a 2bbl but didnt know if they made an adapter that fits the 1965 block i have. maverick_076_original.jpg
  2. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    My not be jetted right and accelerator pump may not be putting out enough squirt so you get to much air and it bogs or stalls. Is your accelerator pump adjustable? What did the carb come off of?
  3. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    With the air cleaner off and the enging off look down the carb and pump the gas. You should see a nice little stream of gas squirting out. If that is not the problem I would check the timing.
  4. rthomas771
    I notice in your other post that you are using a '65 carburetor. If you're using a 67-up 200 distributor then you need to use a Loadomatic distributor. The early carburetor doesn’t feed enough vacuum to advance the later distributor. In other words, the carburetor has to match the distributor...mixed parts don't play together. Are you sure it's a '65 block and not a 64 block? Pre '64 200's had solid lifters and adjustable rockers and the block have four frost plugs located under the exhaust manifold. 1965 and later 200's have hydraulic lifters and non-adjustable rocker arms and five frost plugs. The hydraulic lifters are non-adjustable. The pushrod will need to be replaced with either longer or shorter pushrods. To adjust solid lifters see: http://falconfaq.dyndns.org/display...p_Manual_64&db=Falcon&table=FSM_64&Page=8-010 and http://falconfaq.dyndns.org/display...p_Manual_64&db=Falcon&table=FSM_64&Page=8-011
  5. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    I was thinking the same thing. That is, a vacuum advance problem.
