help with finding shock brackets to work with ford 9 inch
Discussion in 'Technical' started by maverick7072, Feb 11, 2017.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I have a 9 inch out of a 58 ford car and I got the shock mount brackets from the donar car . the mount on the passenger side works but the driver side isn't gonna work for mounting my left side shock. can anyone point me in the right direction as to where I can find new or used shock mounts that will work with the 9 inch in a maverick
  2. Krazy Comet
    Why can't you use the originals??? I assume it's a size issue??? I'm also guessing the '58 won't fit because of the staggered shocks... If so 4-Speed Cobra jet Torino & Mustangs used that setup(also Boss Stangs)... I'll also guess those use larger axle tubes than did '58 Fords...
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    the maverick mounts are too small and the 58 mounts are not staggered like the maverick mounts ,but does anyone know if i can just use to Rh mounts?
  4. bmcdaniel
    On mine I used Mustang mounts for an 8" since my car originally had the small 6-cylinder rear end with really small plates. Slotted the bolt holes in a milling machine for the wider u-bolts. Also the shock mounting ears weren't at quite the right angle so I cut about 3/4 of the way through them, bent them to the correct angle and welded.
  5. Acornridgeman
    Wisconsin
    I too have a '57 - 9" in the '72 car. Took a set of staggered 8" plates that either came from a '68 Cougar or possibly a V8 Maverick (long time ago - don't remember). Used a dremel tool to elongate the holes for the wider u-bolts and they bolted right up.
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    if you want weld on customs / universals, check somebody like fatman fab, or rustys off road..
  7. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i found another set of brackets for a 58 ford car on ebay and i bought them and im just gonna use the right side on the driver side
  8. rthomas771
    Watch for shock absorber angle.
  9. baddad457
    :slap: I took the easy way out and bought and installed a set of Lakewood traction bars. Two problems solved at the same time. :idea: :idea:
