help with key switch
Discussion in 'Technical' started by maverick7072, Mar 2, 2020.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i need to replace the key switch in my 72 maverick can anyone give the steps to do so thanks
  2. 71gold
    may I ask why you need to replace it?
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    71 gold as im starting the car the switch doesnt retract back after starting it,i have to turn it back myself
  4. Krazy Comet
    That's probably linkage or a lubrication problem with the wheel locking mechanism. The return spring is inside the ign sw that's mounted on top of column, just under dash. If that's problem it's new switch time.
    You'll have to remove steering wheel to replace lock. Switch is replaceable by unbolting column and allowing it to drop a couple inches.
    71gold likes this.
  5. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    what do i need to lubricate to see if thats the problem
  6. 71gold
    I use...lithium grease spray.
  7. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    where can i possibly find this in a spray
  8. Krazy Comet
    If key is tight turning to start and back to on, something is binding or needs cleaned/lubricated.
    If it turns easily to start position and back to on, 99% a switch problem.
  9. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    thanks for the tip in this case it sounds like a switch problem an dby switch u are talking about the switch mounted down on the column correct?
  10. mojo
    mojo "Everett"- Senior Citizen
    I would change that switch, assuming it's the original, regardless, making it a process of elimination. If that's not the problem -- keep looking. It's not expensive or difficult thing to do.
