Help
Discussion in 'Technical' started by anthonyv90, Nov 22, 2013.
  1. anthonyv90
    anthonyv90 Member
    South Los Angeles,California
    71 maverick,69 429 thunder jet T-Bird.
    I have a 71 200ci maverick the car turns on but won't stay on unless u put ur foot on the gas and brake.
    The car ran fine a few weeks go
    What can be wrong with it.?
    Thanks in advance
  2. Moneymaker 1
    Panama City Florida
    Vacuum (spelling) leak.
  3. anthonyv90
    anthonyv90 Member
    Any idea where to look first.?
  4. Moneymaker 1
    Panama City Florida
    I would listen for it if you could keep the car running, just check all the hoses you can see for holes or burnt spots.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    if there's no obvious leak at the vacuum pot in the dstributor.. and the vacuum pot holds vacuum?.... I'd move away from a simple vac leak causing the issue you describe.
    Do you have points in the distributor?.. if not.. then I'd be looking towards fuel related issues next.
  6. Bryant
    how old is the gas. ive had gas that is just 3 months old go bad and cause cars to run bad. put fresh gas in and all is good.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I use a can of Berryman B-12 to find vacuum leaks. With the car running spray around the outside of the carb and vacuum lines. When you spray over the leak it will be obvious by the way the engine temporarily smooths out.
