Help!
Discussion in 'General Maverick/Comet' started by SamsDad, Feb 18, 2014.
  1. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    Ok so I got a knocking well ticking sounds just like lifter tick, it wasnt doing this until after I decided to mat the heck out of it and took her up to about 6200, after there was a small ticking and I assumed lifter.
    Now I have pulled every roller, inspected the rod for bent, the roller for free bearing movement (only 12k miles on them) then set zero lash plus quarter turn, then half turn, still ticking. So I decide to loosen poly locks, fire it up and tighten each one until it quit, it never quit as I tightened until the engine rpm would barely lower telling me that I had gone plenty far then I backed it back up.
    The ticking is coming from the right bank facing engine and I'm at a loss, would a collapsed lifter be the culprit?
    And no it's not a leaking head or exhaust gasket, definately a metallic ticking, anybody know what I'm missing?:hmmm:
  2. grbmaverickmo
    Aquashicola, PA
    Broken piston skirt. I had it happen to me. Just a idea to look in the oil pan for pcs
  3. SamsDad
    SamsDad Member
    Little Rock, Ar
    unsure
    I have changed the oil, no metal however didnt pull pan, but this is a constant ticking (loud), how would a broken skirt make a consistant knocking/ticking?
  4. 71gold
    do the rubber hose thing and find where the noise is coming from. should be able to put it on each rocker arm to locate it if it's a lifter...:yup:
  5. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Check springs may be broke doubt it tho
  6. SamsDad
    SamsDad Member
    Little Rock, Ar
    Hose
    Yeah I didn't think about that, with everything I have already done I just can't think of anything but lifter unless I'm missing something which is likely since it's been years since I did any old school V8 tinkering :hmmm:
  7. SamsDad
    SamsDad Member
    Little Rock, Ar
    verify
    If someone will please verify this process on adjusting roller rockers just to be sure ......1.start with either side of engine and turn until intake valve opens, then when it closes and exhaust valve just starts to barely move, back it back up just that tiny bit, at this point both valves are fully closed and zero lash can be set 2.turn nut until just start to feel pushrod get tight (with fingers) then turn 1/4 to 1/2 turn preload then lock it down 3.move to next cylinder and repeat until all have been set. I have done this as well as what I have already mentioned, what gives?
  8. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    when intake opens and starts to close adjust exhaust when exhaust opens and starts to close adjust intake this is for solid roller on standard hydraulic just crank down
  9. SamsDad
    SamsDad Member
    Little Rock, Ar
    huh
    what do you mean on hydraulic "just crank down"?
  10. SamsDad
    SamsDad Member
    Little Rock, Ar
    another possibility
    just read on another forum something that had not even crossed my mind..."wiped cam lobe"...god I hope not
  11. Bryant
    check for an exhaust leak around the exhaust ports. the hose to the ear trick works very well here.
    also when does the clicking happen? all time, only on acceleration, etc..
  12. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    A weak or broken fuel pump spring can sound like a lifter "tick".
  13. SamsDad
    SamsDad Member
    Little Rock, Ar
    clicking
    It happens all the time from as soon as you start it, gets faster as you increase rpm, now since the current exhaust system is so loud I dont know if it goes away when I climb into it or not but I cant hear it once I hammer it, I don't think it's an exhaust leak as it sound's so metallic, however I know leaks can really make a ticking, this would explain why it started after I showered down on it hard if it blew a gasket, I'll try the hose tomorrow.
  14. grbmaverickmo
    Aquashicola, PA
    Just saying yes it will sound just like that. When I broke piston skirt I adjusted the lifters a few diff ways then changed them completely. Wasn`t till I pulled the pan and found the pc laying in the pan off the piston. Also if I remember rite Razersharp did the same thing a few yrs ago at a round up. I kind of remember him having his valve covers off and checking for loose rockers and it was a broke piston. I could be wrong though maybe he will chime in with his finding. What pistons do you have? I had trw `s
  15. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Look at your spark plugs,they can tell you a lot.If any of the tips are whiteish you may have leaned the mtr out,which due to heat will cause a piston to gaul to the cyl. wall.This will cause a constant knock because metal has melted off the piston making it smaller & it will rock back & forth in the bore.Hope this is not what happened because it means rebore & new pistons.:cry:
