hey it does fit!!!
Discussion in 'Technical' started by Mavericknutt, Dec 29, 2002.
  1. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    well I mocked up an engine and trans this weekend to see how it fit.
  2. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    and under the hood too
    even with my aluminum intake it looks like it will set low enuff:)
  3. 71gold
    hi robert, looking good!!!a little snug maybe??...frank..
  4. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    Yea Frank very snug in most places it only has a 1/4" clearance including the master cylinder.....but the motor will be mounted solid (engine plate and solid tranny mount) so i'm not to worried about that I was more concerned with keeping it all under the hood. and that looks good!!I just could'nt bring myself into cutting a hole in my grabber hood.
  5. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    Get out the sawsall because that Hood won't close when you get a carb on the intake:p
    j/k I hope it does.
    don't look like much room to me
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    What is that again ??...
  7. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    that is a 460 setting in my 1974 mav
  8. T.L.
    T.L. Banned
    Southern Colorado
    Well let's just say I WON"T be racing YOU. It'll be kinda hard to steer though, with your front wheels in the air!...
    :D
  9. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Just curious......
    How much had to be cut under the hood? Just wondering. BTW- that's going to be a BAAAAAAADDDDD maverick! Preston
  10. MavJoe
    MavJoe Certified Lunatic
    Sacramento, CA
    1971 Maverick Grabber
    How bout spark plug changes? Thats lookin to be a tad impossible.
  11. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    Preston as far as how much had to be cut out under the hood.....alot!! I changed over my front end to a mustang II so in the process I no longer have the shock towers or inner fender wells. and that also answers your question too joe:) my spark plugs will be easy enuff to change. the 2 things I do know........1 adjusting valves on the driver side might be a pain the master cylinder sets about 1/4" away.......2 to pull the tranny.......I will have to pull it motor and trans.....cause those bell housing bolts would suck.:D
