high rpms
Discussion in 'General Maverick/Comet' started by Eli Lacy, Sep 2, 2015.
  1. Eli Lacy
    Eli Lacy Banned
    1970 ford maverick(grabber clone)
    My mavericks runs about 3500 rpm doing 55, its a 200 with a c4. Any ideas?
  2. Krazy Comet
    Either your trans isn't shifting to 3rd, you have a 4.70(roughly) rear end ratio or the tires are approx 16" tall(you do have tires on the rims?)...
    Ronald Hopkins likes this.
  3. Eli Lacy
    Eli Lacy Banned
    lol its shifting inyo 3rd, and it has the 7.5 rearend. I believe a 3.08 rear gear
  4. Eli Lacy
    Eli Lacy Banned
    I thought maybe the torque converter was maybe slipping?
  5. Krazy Comet
    If the torque converter was slipping badly enough to add a extra 1000+ rpms it's going to over heat and be a dog on acceleration(we're talking inefficient/slipping converter, not high stall speed)...
    Maybe your tach is set for a 4cyl??
  6. Eli Lacy
    Eli Lacy Banned
    I need to change my tach but it seems accurate. is there any vaccum lines to check?
  7. Krazy Comet
    If transmission shifts normally, vacuum isn't a issue...
    As already mentioned, if it really is turning 3500 rpm, the trans should be overheating badly...
  8. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I"d say the tach isn't right
    Craig Selvey likes this.
  9. Eli Lacy
    Eli Lacy Banned
    Ok well ill change the tach and see how it goes, I have had the tach go out. but only for an second. I may also replace the coil, as it is very corroded.
  10. 71gold
    I think you should be able to tell if the 200 is really turning 3500, without a tach...:yup:
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    No doubt.
    Put it in drive.. hit the gas.. listen and learn through first gear.. listen and learn through second.. listen and learn after it hits third. No tach required.
