High torque starter
Discussion in 'Technical' started by PART-TIME, Nov 5, 2005.
  1. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Has anyone tried the high torque starter? Are you happy with it? Is it worth the money?
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Which "High Torque" Starter are you referring to?
    '91-'95 Mustang?
  3. Mavaholic
    I bought the Power Master from Summit. No complaints.
  4. 71gold
    "love it"....fank...:bouncy:
  5. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Rick,
    It's for the 302's in our Mavericks. I saw one advertized in the Auto Krafters magazine awhile back. Can't remember the brand. My starter is beginning to act up when the engine is hot. I'll check the Summit pricing also.
    Thanks,
    Ken
  6. scooper77515
    I would like to see one that has, not more torque, but less size...our starters are way too big to fit around all the headers, trans lines, etc.
  7. Jamie Miles
    Alto, GA
    I've had a few
    Is there any reason a '94-'95 Mustang starter wouldn't work?
  8. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Scooper,
    The torquers are smaller in size than stock, and they will turn the engine over alot faster.
    Jamie,
    Don't know what year Mustangs that will interchange.
  9. scooper77515
    Cool! That is what I was looking for.
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Yes the 95-95 mustang starter will work......Just have to do a little wiring.....
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    ditto (y)
  12. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I have a Power Master as well and I am very happy with it. I used to have all kinds of problems with the rebuilt stock starters I was using. My 302 is not high compression either. Now my Mav sounds like an old MOPAR when I fire it up though...:)
  13. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    What part # are you using? There are a number of Powermasters for the fords.
  14. Maverick Man
    California
    mine was worth it! but sound like the car has no compression now it starts so easy :p here is a thread about it. http://mmb.maverick.to/showthread.php?t=14325 many peeps on here helped me with it to who to hook it up. thanks again guys!
  15. Mavaholic
    I used a PWM-9503. Since these starters come with a built on solenoid, you need to add a jumper from the battery post to the solenoid post on the starter. Very easy to do and small ga wire is all thats needed. Some guys use the starter mounted solenoid and get rid of or wire around the original one on your car. I personelly dont recomend this because your starter cable down to the starter will be hot all the time. Kinda like those "c" cars. I'd prefer to keep mine working like old Henery intended it to be.
