Hole in Radiator.
Discussion in 'Technical' started by Bioinfomatic, Jun 1, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I have a small pin hole in my radiator at the top in the seam, I was wondering what would happen if I drive it daily, for about a week until I have money to replace it? (Daily meaning to me at least 15 miles a day.)
  2. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    It won't do much of anything as long as you are not overheating. Just make sure your fluid level is kept up. A radiator shop might be able to re-solder the seam instead of replacing the radiator. Try to keep the fluid off of the paint, just rinse it with some water.
  3. maverick75
    mine had a hole in the same spot and i just soldered it with those $17 kits you can buy at Home Depot.
  4. stmanser
    Davenport, Iowa
    depends on how bad it is, but stop leak will work, or coffee grounds
  5. PaulS
    That seam in the top tank is infamous for cracking. You can solder it (like I did) but it just keeps ripping. I had to take a piece of brass sheet and form it over the seam and solder it in place to stop the leak. Then I replaced it with a three row radiator for better cooling.
