Hood Hinge repair?
Discussion in 'Technical' started by MikeG747, Feb 20, 2006.
  1. MikeG747
    MikeG747 Member
    Arkansas
    Does anyone have a good sloution to sloppy Hood Hinges. I would think a machine shop could maybe replace the steel rivets? Has anyone done this or have any other ideas? When I am running about 70 mph the back of my hood raises about a 1/2" about the cowl. Looks kinda cool but I think I want to fix this. Don't want my hood to fly up.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Mine does also ... I figure I get better engine compartment cooling that way .... :) I don't see how this would let you hood pop open though ...
  3. 71gold
    sounds like a "hood hinge adj." :huh: to me...frank...:bouncy:
  4. MikeG747
    MikeG747 Member
    Arkansas
    Frank the hinges are adjusted properly. The hood is flush when sitting still. It only raises at 70 mph. When you slow down it drops back down. I think they have just gotten sloppy where the pivot points are.
  5. Robby5323
    Robby5323 Member
    East Texas
    Mine does the exact same thing... I have wondered about this for quite some time?:huh:
  6. Jamie Miles
    Alto, GA
    I've had a few
    Only time mine ever did that was when I was comeing back from the junkyard in my '74 after buying a Comet hood and only had one bolt per hinge holding it down. The hinges on that car were very well worn (had alot of side to side play) but it never lifted with all bolts in and tight.
  7. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    I Cut a BIG ol hole in the middle of mine and it doesn`t have the problem you guys have!:D
    Thats ONE solution!:tiphat:
  8. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Just wait till it hits 88 mph.......You'll see some serious s$$t....:biglaugh:
  9. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    My current hood hinges are worn out too... I have just been too lazy to replace them with any of the good pairs that I have around. :)
  10. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Lower your hinges a little and that should keep the hood from rising. Don't get it to low or the hood will the the cowl. Try that and see.
  11. Mavaholic
    Try taking the hinges off, put one side against something real solid, and use a BFH to retighten the rivits
  12. 71gold
    that is how i tightened mine. i used a big center punch so to spread the center outwards...frank...:bouncy:
  13. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    Mine would have to be re riveted then. They both allow the hood to rub the cowl hard every time. where can I get this done?
