Horn Question
Discussion in 'General Maverick/Comet' started by J.Hope, Dec 1, 2003.
  1. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    My 76 has started doing something crazy! every morning when I'm starting it the horn blows, by it's self three time quickly, i.e. beep beep beep. I asked a friend who has been working on cars all his life and he doesn't know what it means. My Mom owned the car from when it was new and I have had it for 6 years and it never did it before. Anyone out there have an idea?:confused:
  2. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    Ok, I ain't any expert, so...
    ya gets what you pay for, but...
    Follow the wire back all the way from the horn to the horn switch, if you can. Look for any bare spots, sounds like it might be shorting somewhere... ?
    Or something is inducing current in that wire..
  3. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    It sounds like a bios beep code on my computer....check your memory, it may need to be re-seated.
    (sorry couldnt resist, computer humor....)
    JP
  4. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    So you're saying,
    his Maverick is failing it's POST (Power On Self Test? )
    (Bwahahaha!)
  5. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    yep sounds to me like your wire is bare somewhere on the column.......your ignition rod is probably rubbing on it
  6. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    or wait............they dont have a rod do they.........(scrathes head):D
  7. Bigh4th
    Bigh4th Member
    Dinwiddie, Va
    70 maverick grabber
    maybe you need to pull the codes from the computer :D :D :D
    -Harry
  8. inline6
    inline6 Member
    you have to check the flux capacitor,to make sure it is recieving the needed 1.21 jigawatts!......check the wire coming from the horn,more than likely the insulation has rubbed through,causing a short,in the system..good luck...chuck.
  9. Mavaholic
    Ok, these horns are grounded through the mount and the wire going to the horn supplies 12 volts. A short in the wire somewhere would just blow the fuse, not sound the horn. The problem is probably somewhere in the horn button (or pad) or the steering wheel connections. There are 2 brushes in there that ride on rings on the back side of the steering wheel. Probably one of the brushes is intermittently shorting the tracks together. I would check the horn pad first, then pull the steering wheel to check the rest.
  10. 71gold
    dennis, i was on the same train of thought but that would make it blow at anytime not just on start up. he could just turn the wheel and the horn should blow. it also should blow when the key is off. on the other side it will make people think he has remote door locks and he is locking the doors, just needs to flash the lights at each start up. that is about the only thing that hasn't happened to one of my mavs...frank...:bananaman :bananaman L.T.N.G.
  11. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    But isn't there the possibility,
    that something is inducing current in the horn wire?
    Although, I can't see how you'd get enough power there through induction to blow the horn,
    Very odd....
    Check the horn switch too, there may be something wrong with that too.
  12. andwrong
    andwrong Member
    denial, DTC colorado
    losers dont have cars
    I completely removed my horn and installed a 14" grant wheel from autozone :D works good for me
    oh... and to get people to move just rev it up nice and loud :D i made one lady jump out of her seat by doing that.
  13. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    Just so happens that I changed out my steering wheel as well, and ever thing from the black wire out is brand new. I have traced the wire from the horn back to the steering wheel and its not nick broke or even rubbed hard any where along the way. I was thinking that the 3 horn beeps was a indication of some part like the module was starting to go or something. The module on the is car is one of the few parts that I haven't changed to date.
  14. bmcdaniel
    bmcdaniel Senile Member
    I had a similar problem once, the horn would blow for no reason, sometimes when I was sitting still and sometimes when I was driving. People would look at me and wonder why I was blowing the horn at them. The problem went away when I replaced the steering wheel.
  15. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    its saying CHANGE MY OIL !! LOL:bananaman
