horsepower
Discussion in 'General Maverick/Comet' started by 1974fordmaverik, Jan 7, 2011.
  1. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    quick ? how much horsepower does a 1974 stock 302 5.0L have in it
  2. PaulS
    Do you want an actual number or the factory rating?
  3. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    either or works
  4. PaulS
    It was rated at 140 - 142 hp depending on the source but it actually produced a bit more than that
  5. 1974fordmaverik
    huber heights Ohio
    74 Maverick
  6. chevyandford71
    chevyandford71 Member
    Apex, NC
    1971 Ford Maverick Grabber, 1991 Honda CRX HF w/B18A1 swap, 2001 Honda CR80R
    what about a stock 71 250 i6?
  7. rthomas771
  8. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Bet it doesn't push much over 100 at the wheels.
  9. maverick75
    With a 20 percent loss through the driveline it should be like 112 WHP, and thats not taking into consideration the condition of the motor. So it could be even less.
  10. 69GT
    69GT Member
    Fresno
    Yeah I remember some guy dynoed his 70 something F code 302 and had something like 93 HP at the wheels. He had a C-4 so that accounted for some parasitic loss but geez...
    Ford built these motors like tractor motors. Their torque peaks at around 1800 RPM They are all done by 3500 RPM in stock form.
  11. Awesome_X
    Awesome_X Member
    Oklahoma
    Isn't there a lose of horses over the years do to engine wear and tear?
  12. chevyandford71
    Apex, NC
    but cant you regain it through a tune up?
  13. maverick75
    Yessss, as cylinder walls tend to wear they lose pressure. Other things also cause a loss of HP, like carbon build up. Worn out carbs, etc.
  14. maverick75
    Only if your tune up is a rebuild :D
  15. Awesome_X
    Awesome_X Member
    Oklahoma
    So that 100 would be more like 70 to 80 horses.
