i have a blaster 2 coil, a new msd 6462 ignition with the boost controller (no turbo or supper charger so im not going to use the adjuster knob) and an accel points eliminator kit. first question do i have to use the ballast resistor? and then how do i wire up all this stuff.
here are the instructions http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Ignitions/6420_instructions.pdf
im guessing its the last diagram i think its just like the petronix kit. this is the one i used http://www.summitracing.com/parts/ACC-2020/
The accel kit already has an ignition module. You probably wont even see a gain(let alone feel it) if you swap over to the msd box. Sell the box, buy a chain and keep the change. Then enjoy your car
