How did this engine stay together for 14 passes?
Discussion in 'Technical' started by rayzorsharp, Aug 26, 2006.
  1. rayzorsharp
    Hey Round-Up guys...I finally got time to dig into my engine to try to find out where the tapping noise was coming from. I had a couple of our engine techs listen to it with me before I starting taking it apart and they too thought it was in the top end. Well, I took the head off the noisy side and couldn't find anything obvious, even after completely disassembling the head. The cam checked out great, lifter bores were fine, had already replaced the lifters. I replaced a couple of the roller rockers at the motel before going to the track hoping I might get lucky as some of you know. Anyway, after running out of things to look at I finally decided to drop the pan and take a look at the pistons. There she was...a nice visible crack in the #6 piston skirt. I took the cap off and as soon as I started to push the piston upward, the bottom of the skirt fell into my hand. There appears to be a hairline crack on #2 also so she's coming all the way out now. I just can't believe that after making 14 passes on the track that it stayed together and I was turning her up well over 6K too. I guess I got lucky but then again I'm not sure yet if I did any block damage. I'll know more tomorrow when I get her on the stand. Anyway, here's a pic on my tapping noise:
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    What brand piston?
    Good thing it didn't ruin your fun at the track:bananaman
    Is this the motor that got water logged?
  3. rayzorsharp
    TRW's...and yep, the same motor.
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Amazing.
    Yeah, what kind of pistons are those?...
  5. Mavaholic
    Built Ford Tough!!!!
    Glad it held together long enough.
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    amen to that, build ford tough:yup:
  7. don graham
    me thinks you got a little bit lucky ray.:yikes:
  8. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Wow!!! I woulda never guessed that. Amazing.
    Dan
  9. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I had a '74 Torino with a 302 do that exact same thing. I had to have the block bored and use oversize pistons.........and I thought I was lucky when my lug nut feel off after driving 3800 miles.......Glad you found what it was
  10. Craig Selvey
    Man...that could have been scary stuff.
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sorry to hear that Ray, you got lucky!
    Who originally built the engine? Sounds like to much piston to cylinder wall clearance or rod bearing failure.
  12. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    SBF pistons are notorious for cracking at the skirts.
    Even Boss 302s had the problem when new... and those pistons were sourced from TRW if memory serves.
    Glad you caught it at a safe moment Ray.
    Dave
  13. Dan Starnes
    West Central IL
    Still freaks me out that the little tick we were hearing was that.
    Dan
  14. T.L.
    T.L. Banned
    Southern Colorado
    Forged?...
  15. rayzorsharp
    yep...but quite old. They don't even make this particular one anymore. :huh:
