How do I get decals off of a fender
Discussion in 'General Maverick/Comet' started by Greg, Feb 26, 2004.
  1. Greg
    Greg Member
    Lincoln IL
    1973 Maverick
    I have a Fender from a 76 Stalion. It is all I have of the Stalion so don't think I'm trashing a 76 Stalion. I want to put this on my car but I need to get the black stripes off of the finder so I can get it painted. Does anyone know how I can get these almost 30 year old factory decals off of the finder. I have tried to us a razor blade and that will be very slow. Has anyone tried this?
  2. 4speed
    4speed Member
    IUKA, MS
    69 Falcon Wagon;1982 Bivouac Mustang Convertible;1985 Crown Vic Station Wagon
    6" side grinder! :D
  3. antjc600
    antjc600 Member
    Quakertown, PA
    Cometless
    you can try heating them up with a heat gun. if that doesn't work you can get an eraser wheel for a die grinder. One of them should get it off without damage.
  4. 71gold
    i use a hair dryer...frank...:bananaman :bananaman
  5. Jean Doll
    Palmerton, PA
    With tough old decals and stripes, I hold a rag soaked with paint solvent on the decal until it softens. Then scrape the decal off with a razor blade scraper. Any glue left behind will also be softened by the solvent and can either be scraped or wiped off. The solvent will soften the paint too, but since you are going to paint the fender anyway it really won't matter.
  6. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    sawzall
  7. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Listen to Jean....
    ...these other methods are tedious.
    The eraser works, but it is still time
    consuming.
    Your paint/body supply shops carry
    a chemical specifically for these jobs
    but I am guessing her idea will work
    just as well.
    Seth
  8. Mavaholic
    Sometimes decals can etch the metal too. So if you dont put a primer/filler over it or enough coats of paint, you can sometimes still see the outline through your new paint. Check it good before you start spraying color. I have personally just sanded off the decals with a DA and 80 grit.
  9. Rust Bullet
    Rust Bullet New Member
    Dallas, Texas
    1967 Camaro SS/RS 396
    Soak the decal with WD-40, give it 20-30 minutes and it will peel right off.
  10. Greg
    Greg Member
    Lincoln IL
    1973 Maverick
    Thanks for all the suggestions...and mavaholic I will look out for the etching
    Thanks
  11. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    if your going to repaint the whole fender why make it any harder to do? just strip the paint off the whole fender, i would and am personally. last thing i want is failed paint underneath my expensive paint
