How I can turn my flywheel 28 to 50 oz?
Discussion in 'Technical' started by Cemiat, Jan 17, 2012.
  1. Cemiat
    Cemiat Member
    How I can turn my flywheel and damper 28 to 50 oz?
  2. Dave B
    It has to match the balance of the engine, you can't interchange them.
  3. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Depends on the type of flywheel. Dose it have a welded on weight or is it removable? if its welded it would have to be taken to a machine shop and have the old 28oz removed and a new 50oz replaced and balanced
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have seen aftermarket damper's with weights that can be swapped but never a flywheel.
    I suppose a good engine shop could do it but the cost may not be worth it. Best bet is to buy the correct ones you need.
  5. Cemiat
    Cemiat Member
    Tks I don´t want buying a new, I am in Mexico and the shipping is very expensive, I asked in the biggest Machine shop in my city and they don´t know how do it.
  6. rthomas771
    Why do you want to change the balance?
  7. baddad457
    It's easier to do it the other way, 50 oz to 28 oz on either a flywheel or flexplate, but it does need to be done by someone who does engine balancing. And it's easier for them to do this with both weight flywheels (or flexplates) to match balance it. I had one done. All he had to do to match it was drill a few shallow holes in the 50 oz counterweight. To go the other way (28 to 50), weight needs to be added. It would be easier to find the correct weighted parts if no one does this in Mexico.
  8. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    Just a thought here, but if the engine is externally balanced by the harmonic balancer and flex plate, couldnt you just get a 50oz flex plate and 50oz harmonic balancer?
  9. maverick1970
    Missouri
    The parts have to match the crankshaft
  10. Cemiat
    Cemiat Member
    Because I put a engine roller 96.
  11. bmcdaniel
    bmcdaniel Senile Member
  12. Joe Dirt
    Sounds like you have no choice but to either source used or new parts. Be cheaper then replacing the. Motor
  13. baddad457
    What size (tooth count) are you looking for ? And are you needing a flywheel or a flexplate ? If you can tell me this and give me your shipping address, I can look into what it'll actually cost to ship it to you in Mexico via UPS.
  14. Cemiat
    Cemiat Member
    Thank you, I need Flywheel, my old engine removed today, I'll list the teeth, I reported, I hope that 164 of these I think if I can find in Mexico in a pickup, is the "damper" of a cougar with 5.0 HO I use?
  15. baddad457
    You're running a manual transmission, right ? 164 tooth flywheels were pretty much standard equipment in pickups that had manual transmissions, I've never seen nor heard of one that had the 157. Trucks needed more torque to move them and thus, more gripping capacity from the clutch.
