How in the heck...
Discussion in 'Technical' started by boss9, Aug 14, 2006.
  1. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    do you remove the knobs on the heater control levers ???:mad::huh:
    Want to put the replacement heater control cover on and can't get the knobs off ! I've pulled by hand. I've wrapped the lever with cloth and put channel locks behind the knob and pulled... nothing, they won't budge.
    Darrel
  2. Jamie Miles
    Alto, GA
    I've had a few
    They usually just pull right off for me...
    If you have a real stubborn one that you are planning to replace anyways, I have heard of using a lighter to heat them almost to the melting point and pulling it off with pliers.
  3. blugene
    Sneak some long needle nose behind the knob and use channell locks for leverage and pry:smash:
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    drimmel?? its the electrical counterpart to duct tape...it can fix anything :D
  5. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    Agree
    Cut the thing off!! But if you want to save it, try soaking it down in WD-40 then use the vise grips (behind the lever) and pull. I have done this a couple of times with good results. Old age sets in and the plastic won't let go. You have to help it!
    Jerryfow2
  6. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Thanks guys, trying to save these as they are in good shape. I'll try the suggestions .
  7. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    use a pick ...there’s a place on the rear of the knob you press the spring and they will come right off
  8. Acornridgeman
    Wisconsin
    I have pulled 100's of these and once in a while you will get some that are tough. Genes idea of getting behind it with 2 tools for leverage is a good idea. I have an old pair of hard plastic spark plug wire pliers that fits nicely behind there. What you want to do is push it from behind, so it pops off, rather then grip right on it. Gripping on it will leave pliers tooth marks in the chromed plastic.
  9. grbmaverickmo
    Aquashicola, PA
    needle nose vise grips on the metal part then I use this snake tongue looking tool behind the knob to pop them off.
  10. bmcdaniel
    Geeze, mine fall off.
  11. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    :rolleyes: Must be nice !! Mine are currently soaking in PB Blaster (hoping the chrome doesn`t eat away). Next step is to heat up the arm.
  12. MaverickGrabber
    Cardington, ohio
    i used the pick to pull them ....worked for me :tiphat: just fig they was the same
  13. captainmack
    captainmack Quad Door
    Anybody know where I can buy these knobs? I need 3....Thanks!
  14. Acornridgeman
    Wisconsin
    Put a wanted ad down in the classifieds - I'm sure there are a bunch floating around here on the board. Ebay has them all the time too.
  15. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I'm was in the same boat, little nail polish stuck them on there:dance:
