how much power would I lose using manifolds?
Discussion in 'General Maverick/Comet' started by slopoke, Jan 7, 2015.
  1. slopoke
    slopoke Member
    San Antonio TX
    1977 ford maverick
    I am a couple weeks away from installing a 351w into my 77. Im under the impression that my 6901 headers will not work. So my question is, what would the power loss be (rough estimate) if i used manifolds until i can spring for the crites headers? This is a modestly built engine 350hp at the flywheel.
    thanks in advance for your input.
  2. Acornridgeman
    Wisconsin
    I remember reading some magazine articles where they did dyno tests on different headers vs stock cast iron manifolds. 10-15 hp was the norm. I think like 25 hp was the best. Had a lot to do with RPM ranges too.
  3. scooper77515
    I don't think you would notice it if you weren't drag racing and watching an ET clock.
  4. 71gold
    if you are going headers...why worry about it? (10-15)
  5. scooper77515
    It will sound different, quieter, less "pingy". Otherwise, I doubt you would notice much difference.
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Depends to a degree on the heads and cam. On a stock engine, I would expect the losses to be in the 10-15 HP range as suggested. Throw in a good flowing set of heads, more aggressive cam timing, RPM limit and the loss would be significantly higher staying with manifolds.
    We used to see this with marine engines all the time.
  7. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    If you have to use manifolds, smooth them out and port them. 15 hp on a 350 hp mill sounds about right.
  8. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    I agree with scooper77515 above. If this is strictly for street use I doubt you'd notice the difference. It will be quieter inside the car. I have had cars with headers on the street before and, trust me, the resonance can get old after a while.
  9. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I have done a couple of these swaps and I will bet that a 351W will not fit unless you have modified the spring towers.
    Lee
  10. slopoke
    slopoke Member
    San Antonio TX
    1977 ford maverick
    I have notched the shock towers and done a few other mods on top of that. Im thinking ill just have to bite the bullet and order the CRITES headers after I try and modify my hooker 6901's (and fail) of course.
    and thanks to everyone for the replies... most helpful! This is one of the best forums on the net. Thanks Guys
  11. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That's a good looking job on those towers.
  12. slopoke
    slopoke Member
    San Antonio TX
    1977 ford maverick
    thanks jasonwthompson, i drove myself nuts trying to get them perfect! Had to force myself to be happy with it lol
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    If you're NOT currently running a very high flow and correctly sized exhaust system?(most aren't with cookie cutter sized bolt on parts and crimp bent exhaust pipes).. the manifolds will cost you a solid 25 horse up top and cause your peak to fall off MUCH quicker. This of course cuts the rev range and more importantly.. AVERAGE power.
    IF.. you already have a better sized system that still flows sufficient mass for these small motors?.. the losses will be even greater. IMHO, very rarely does a 302 need anything more than a 1.5" - 1.625" primary pipe.. matched to a 2.5" collector. Anything larger gains flow with a major loss in gas velocity as the compromise. Never good to lose velocity right near the start and towards middle of an exhaust system.
    Oops.. too many tabs open. A 351 can extend that optimum sizing towards a 1.625" primary matched to a 2.5" collector. If you ever intend to stroke it, and/or run more compression, and/or rev it higher?.. step up to a 1.75" primary and a 3" collector.
  14. slopoke
    slopoke Member
    San Antonio TX
    1977 ford maverick
    Good info groberts101, I agree on primary and collector sizes. I currently have zero exhaust so I'm free to do what i want! I have some exhaust plans I'm going to keep under wraps until completed but for now, probably just 2.5" pipes,quietest mufflers i can find and dumps. I also decided to buy several used sets of headers(not manifolds) for various makes and models under 50 bucks a piece (craigslist). I thought i would see what would be the easiest to modify, and re-sell the others. Im hoping to find a cheaper option than CRITES. I spent too much money on the 351 to justify using manifolds and losing 25 hp. I guess we will see how it goes.
