how to make my maverick handle better...
Discussion in 'Technical' started by random hero, Jul 12, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    i recently purchased disc brakes for my mav and now i need to get new wheels and tires (4 lug-5 lug conversion) i have 14 inch wheels, and i want to go bigger...but not tacky. maybe 17's for a resto-mod look. but performance is more important. i'm not sure what rim/tire combo will give the best handeling. 16x8 17x8 any suggestions. also what else could i do to increase handeling?
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I just went through this myself. The tire will probably have more of an effect on your road handling than 16" vs 17". Wider in the front will make turning harder but will give your more of a grip.
    I got the most bang for my buck by installing a sway bar in the back and a bigger one in the front. That by far made the car handle the best. Then after I got an alignment I noticed another HUGE difference.
    I had all the front end parts replaced (except springs) and that did nothing in my opinion. I'm sure made the car safer but that's it.
  3. maverick maniac
    maverick maniac Banned
    owensboro ky
    the best way is to change the rear spring to a 5 spring set up that will give you most bang for the buck (and sway bars of course)
  4. mavgrab302
    Bigger sway bars and lower the car a couple inches. tire combo will help too......
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm not familiar with a 5 spring setup, what is that exactly?
  6. Positively Ralf
    Yonkers, NY
    1974 Maverick
    You guys talking about the leaf or coil spring here?
    Also, how hard is it to install a sway bar cause if it can improve the ride I'm all for it.
  7. Positively Ralf
    Yonkers, NY
    1974 Maverick
    just a bump for an answer!
  8. jbbossmav
    jbbossmav Member
    md.
    71 maverick grabber
    they are talking about the leaf springs. do a search on rear springs and you will see there are guys who have taken leafs off of an E-250 or E-150 van (im not sure which) and used them on the maverick. you can mix, add leafs to get the ride you want.
    i got 620 lb mustang lowering springs for the front and i'll lower the back to match.
    i got a 3/4 sway bar for the rear and although ive read a few arguments here about using mustang swaybars on the front. im going to give it a try.
    im also using 7x17 and 8x17 wheels.
    should handle pretty good if i can ever get some ~%^*ing headers that fit!
  9. maverick maniac
    owensboro ky
    Sorry had that wrong it is a 4 leaf spring set up you take out your leaf springs and replace with the 4 easy to do and helps a lot
  10. bmcdaniel
    Put a Corvette chassis under it.
  11. maverick maniac
    owensboro ky
    now lets keep it in the same family t bird or Lincoln both have independent rears
  12. bmcdaniel
    Yeah, but they don't handle like a 'Vette.
  13. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Depends on which 'Vette you are talking about, I think they both handle allot better then a cheVette :rofl2:
  14. maverick maniac
    owensboro ky
    that has to do with the flex of the unibody if ford would have done something about that they would
  15. Mavman72
    Stiffen up the chassis(subframe connectors)tighten up the front/rear suspension(new parts...Not urethane either)Lower the ride height front/rear.Add Sway bars front/rear.If you have a V-8 use at least a 7/8" bar up front.Good shock absorbers all the way around(not wall mart cheapies)tie the towers together with a montecarlo bar(not the car)now go to a light weight wheel tire combo with a soft rubber compound and some upgraded brakes to help shed speed when you are late braking through the corners in your neighborhood(dont do that in town)Theres alot to making a car handel.Taloring spring rates form fornt to back side to side.Different alignment settings,castor/camber and toe.Stiffening the rest of the cars body/chassis.Engine set back for weight distribution etc...It can get pretty heavy and long haired with the math and such.The basics listed above and all through this thread are enough to make you happy with a street car.Good luck!!!
