How To Set Timing On 71 Maverick 302
Discussion in 'Technical' started by cornfed344, Jul 7, 2007.
  1. cornfed344
    cornfed344 New Member
    oregon
    1971 maverick
    I,m In The Learning Stage Still.....
    How Do You Set The Timing For A 71 302 Maverick.
    I Have Replaced The Points With A Pertronics.
    I Have Also Replaced The Alternator, Spark Plug Wires, Spark Plugs, Battery, Solenoid And Dist Cap. The Only Thing I Haven't Replaced Is The Coil And Voltage Regulator.
    The Engine Wont Run. It Cranks Just Fine, But Won't Run.
    Any Help Would Be Greatly Appreciated.
    Thanks
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    If you have the dizzy even close to TDC the engine should fire and run. Pertronix can be tricky ... make sure you have it hooked up correctly ... if it doesn't have a constant 12V it will not work.
  3. blugene
    Verify that fireing order, counter clockwise 15426378. :burnout:
  4. Mavaholic
    Did it run before you started replacing parts?
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    same thought here, usually if you have the timing real far out of wack...it won't "crank just fine"
  6. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    pull your distributor cap and see if u put your rotor back in...i forget about it sometimes...lol
