Howdy- first question, HELP!
Discussion in 'New Members Forum' started by hotrodbabe, Jun 13, 2014.
  1. hotrodbabe
    hotrodbabe New Member
    Ohio
    1973 Mercury Comet
    I need your guy's help!
    I have had my 1973 Mercury Comet for almost four years and I keep going through starters like boxes of cereal. I'm on my seventh one because the bearings keep breaking on the inside. Two/three weeks ago my starter went out and I was told to shim it, so I did. Well yesterday, my starter went out again and my dad and I are stumped on what the heck to do. :hmmm:
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    manual or automatic?
  3. rthomas771
  4. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!! BTW, what engine and transmission are we talking about??
  5. blugene
    :Welcome:
    I would not use the advise from someone who told me to shim the starter IMO. Eagle Transmissions in Mesquite TX did that to mine and it messed up my flywheel AND the starter. There are several factors that need to be know in order to begin trying to help figure this out. rthomas771 has posted a good read that will help you identify what your looking at in your hands.
  6. mav1970
    As Paul said - need to know what engine and transmission you have :)
  7. 71gold
    :Welcome:...:Handshake
  8. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Yes Bluegene is correct, :naughty:no shims,and keep the starter bolts tight, also clean the threads. Do not cross thread the bell housing. Ford bell housings can be helicoiled, but you might not want to. :16suspect :tiphat:
  9. hotrodbabe
    Ohio
    1973 Mercury Comet
    Thanks guys! She's automatic, 250 6cly 4.1
  10. 71Mavrk
    71Mavrk Member
    Nevada
    Is there any chance that the first time you replaced the starter you got the wrong one and you just keep buying the wrong one over and over?
    Double check that what you are buying is correct.
    My car had the same engine and trans as yours and the starter lasted 15 years before it finally failed.
    Micah
  11. SlotlessMan
    SlotlessMan A squirrel and his nut
    Chetek, WI
    71 Grabber
    :Welcome:from Chetek, WI
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  13. kirkds00
    kirkds00 Member
    Milford Ohio
    1973 Mercury Comet, 1969 Ford Galaxie
    Dad here, We have the correct starter. Have replaced 7 times. Starts great for a while then bearings shatter. Flywheel is good and has been replaced. The reason we shimmed it this time was due to the first 6 times we didn't. Ford didn't use shims but I was told by a 30 year Ford mechanic that they had to shim ford starters many times over the years. Only one shim even available for this car so we gave it a try. Started perfect for about 3 weeks then out again. We did have 1 that lasted for a year prior to this one. Purchased starters from 2 different places and 2 different manuf. Hope this helps a little. I am stumped. Engine needs rebuilt or replaced but wasn't ready for that yet. Just never saw a car go through starters and I have messed with them for 30 years.
  14. Craig Selvey
    Where are you getting the starters?
  15. kirkds00
    kirkds00 Member
    Milford Ohio
    The first 5 were auto zone. We were later told NEVER buy auto zone starters. I went back to Smyth Automotive after that (which is where I have always bought my parts for 30 years). 1st starter from there lasted 1 year. Lifetime warranty so I swapped it out. 2nd one lasted 3 weeks.
