I HATE Potholes!!!!!!
Discussion in 'General Maverick/Comet' started by 408w-maverick, Nov 11, 2009.
  1. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Hit 1 hole and look what freakin happens!!!!!!!
  2. mean_maverick
    that must have been a big ol' hole!!!
  3. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    thats what i was thinking! musta been huge!!! :mad:
  4. Jamie Miles
    Geez, you sure you didn't hit a freakin' crater!? Maybe the grand canyon?
  5. 408w-maverick
    Oklahoma City
    lol yea it was like 6" or 7" deep,i got little front tires so they didnt absorb much of it,instead it all went to the mount,the other bolt was ripped out and theres still metal in the threads.
  6. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Dukes of Hazard style huh? Might better fab up something stronger now...
  7. 408w-maverick
    Oklahoma City
    ^Hell i cant afford too,just gotta get a replacement and throw it on and hope i dont it another.
  8. Jeff S
    Jeff S Member
    NoVA
    none
    How bad did it damage the hood ?
  9. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    Yikes, potholes suck big time!!
  10. 71gold
    ...or softer shocks...
    what rate springs are you running?
    ...:yup:,...
  11. CaptainComet
    Geez ... and you don't even live in Michigan ... (worst potholes I've ever seen ... ;) )
    Any one else ever have this happen? Pretty odd ...
    Maybe a change is in order here? ... make the mount tougher by doing away with the threaded inserts. Use grade 8 bolts and nuts with a washer fitted inside to the mount to spread out the load? Not a lot of room in there, but I would opt for a trimmed fender washer rather than a smaller one that fits easier.
    I agree that your combo of small tire, spring, and shock is probably severe in some aspect.
    Does your car still have bumpstops?
  12. Rando76
    Rando76 Member
    Claremore, OK
    These are good questions. I've never seen one do this before. Sounds like something in the setup needs to be changed. :hmmm:
  13. 408w-maverick
    Oklahoma City
    The shock are supposed to be stock replacements i got em at autozone,I plan on goin with The grade 8 set up,and the whole front suspension needs new bushings,its on my long list of things to do...
  14. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Oh no! That sucks man!
    Looks like a simple fix if you can find the part though. I run small front tires and my shocks and springs are factory...good luck.
  15. sierra grabber
    sierra grabber Certifiable
    northern nevada
    at least its a bolt on fix, check that it didnt crack your shock tower inside. been welding and sanding since august because of one i "found" on a cali highway :(
