i have a sbc question
Discussion in 'Other Automotive Tech & Talk' started by justin77, Jun 13, 2009.
  1. justin77
    justin77 Member
    odessa texas
    1977 maverick!!! 64 chevelle, 85 chevy, 86 chevy 90 chevy
    what size motor would a 400 sbc bored 40 over with a 3.750 crank and a 6 in. rod be??? just curious cuz im thinking bout rebuilding my 86 gmc motor
  2. justin77
    justin77 Member
    odessa texas
    yea i know its a lil odd posting chevrolet question on a ford sight but im just wanting to know so plz help me out haha.
  3. Bryant
    i dont know but there is a section at the bottom for non maverick/commet tech questions.
  4. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    Not sure of the size but I believe it will still fit in your maverick, because of the small trunk opening you will have to pull the heads and intake and possibly the pan, once you get it in past the trunk lid should have plenty of room, I would just use sand bags myself:rofl2:
    I have heard that the 400 chevy can't be bored much , pistons are too close together and will run hot, not sure be I remember hearing that
  5. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Need to know the cylinder bore measurement.
  6. rayzorsharp
    Definitely posted in the wrong section :16suspect
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The formula for cubic inch displacement is
    CID = Bore x Bore x Stroke x 0.7854 x Number of cylinders
  8. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    google, Bore and stroke calculator. Some websites will come up to where all you have to do is type in the info and it does the rest for you.
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Yeah, I wouldn't bore a 400 that much unless you live in Canada. Its cooling ability is already marginal because of the thin walls and the small water passages. I think in the Texas heat you'll have a hard time with it. This is why the 383 stroker is such a popular motor.
  10. Joe Dirt
    408 cubes
    3.750 is the stock 400 stroke
    the bore will be 4.165
  11. Mavman72
    Better sonic check the block if your gonna bore it.Thin wall castings dont tolerate much more than 20 over.
  12. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I thought the 400 was a siamese casting?
    I know 4.185" pistons are common for them.:huh:
    If they are NOT siamese, I would be very weary of .040" over.
  13. justin77
    justin77 Member
    odessa texas
    they are siamese castings but i know 400's have thin walls if i do ima get a electric water pumb and fans and a 4 core radiator to make sure i dont crack the block or the sides of the cylinders.
