I need a little help...
Discussion in 'General Maverick/Comet' started by ResterAvecVous, May 9, 2007.
  1. ResterAvecVous
    ResterAvecVous Member
    pittsburgh, PA
    1972 maverick
    I'm getting a 1972 maverick with the 302 as my first car. I'm really excited because I'm buying it from the original owner and its in great shape :D. its an absolute tank and i love it! but what i wanted to know is if anyone had any advice on anything that may like to go bad on the cars or that may need replaced at a certain mileage so i know of anything that might be heading my way. any help would be greatly appreciated thanks! :)
  2. don graham
    sounds like a great deal. one of the things to watch for is the cowl vent in front of the windshield. make sure you pour some water down and see if any comes out on the inside. that is the worst place on the maverick for rust. also check the torque boxes underneath. other than that the 302 is a great engine and with minimal care should keep running for a long time. i'd say check the brakes and shocks and stuff like that to keep it safe. good luck with it and post some pics when you get it. (y)
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Howdy &:Welcome:....... I seem to recall a factory concern with the parking pawl (y)
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Howdy an Welcome! I live in Springdale, Harmarville. Put the aol behind my user name an shoot me a email. Glad to help if I can!
  5. ModMav71
    ModMav71 Member
    Sebring, FL
    I wouldn't call it a tank (neither huge nor heavy)...but it is built like a solid old car should be. Welcome to the board and post pics when you get it!
  6. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    hello from Johnstown, if you are going to check brakes check wheel cyclinder and bearings also and above all (stay calm with yourself)
  7. ResterAvecVous
    pittsburgh, PA
    1972 maverick
    thanks guys! and yes trust me i will have pictures up asap. :)
  8. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Welcome aboard the SS maverick Matey. Capt Mavowar says swab the deck argghhhh and please have your pet spayed or neutered:D
  9. scooper77515
    Welcome aboard...kinda like crack, very addictive, but has a MUCH better buzz (I guess, never tried crack, but i have been hooked on Mavs for 6 years now with no apparent ill effects:D )
    What kinda miles does the engine have?
    Typical concerns are sagging rear springs (fix for $100), leaking transmission gaskets and seals (fix for <$25), the cowl unless you are lucky to buy a garage-kept car like me, maybe some blow by on the valve covers on a high mile engine. But, like they say above, that 302 is indestructible, and will run forever...
    Best thing is for a couple hundred bucks, you can make that 110hp engine put out 300hp:burnout:
  10. Mavaholic
  11. lbr
    lbr Member
    Fresno, CA
    11 second '72 Comet, 302, 4 spd
    The Timing Chain/Cam Gear (plastic teeth) would be my only engine concern. I would THINK it has probably been relaced by now. But I get HAMMERED by someone whenever I Think:D
  12. Halebopp
    Halebopp Member
    Ankeny Iowa
    Hey Scooper, how do you fix sagging rears for $100? Re-arch? what kind of shop would I go to for that? Or is their another option?
  13. mavtricks71
    mavtricks71 Member
    good lord never seen sucha cutie into mavericks!! :)
  14. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    How long you been going to PRP? Does your dad run up there? Was up last week, 2 years ago I had my Maverick running there. Should be soon I have new car running there. Good Luck an don't be afraid to holler.
  15. stmanser
    Davenport, Iowa
    welcome aboard.
    these cars are actually built rather well. not much to work on... of course when any vehicle hits 30, it might need a few things replaced here and there..
    one good rule to go by
    "If it ain't broke, Don't fix it"
    however.. a good restoration can be healthy from time to time
    check the usual.. brakes, oil, steering linkages, etc
