I need a marker light socket. Bulb is broken and stuck in there.
Discussion in 'General Maverick/Comet' started by scooper77515, Jan 31, 2014.
  1. scooper77515
    Is this something I can buy at the auto parts store, or do I need to order from a mustang parts house?
  2. simple man
    simple man Member
    Bunnell,Florida
    You can get the busted bulb base out with some small needle nose pliers. I think Advance Auto parts had this socket in the "help" section. If all else fails, junkyard! The socket that is in the trunk is more likely to be in good shape. (y)
  3. Paul Masson
    1971 Grabber
  4. scooper77515
    I have new bulbs, but just cannot get the old bulb out. I think the contacts in the plug are getting messed up the more I work on them.
  5. Krazy Comet
    Look at a good socket, then drill a 1/16" to 1/8" hole between the contacts at base of bulb(not through just to bulb)... Insert a small pick and pry upward, should push bulb out... Reseal hole with RTV...
    May not work but socket isn't any good now, watcha ya got to loose???
  6. scooper77515
    You are right...can't mess it up any more than I already have.
  7. Bryant
    put some dielectric grease on the new bulbs contacts. it will prevent corrosion from forming and thats usually what makes the bulbs hard to remove and help guarantee that they bulbs get full voltage.
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Those bulbs are so hard to install it's scary. I always use a piece of hose to push and turn the bulb in case it explodes in my hand...
  9. Krazy Comet
    He's talking about the #194 wedge base bulb, they'll take far more abuse than you can imagine...
    Unless they are halogen(didn't exist in Maverick days), bulbs either have vacuum or filled with inert gas such as argon, no pressure, no exploding...
  10. scooper77515
    This one broke while I was flopping the wires all over while shortening and rerouting. When I got around to putting the bulb in and reinstalling, that is when I encountered the difficulty with pulling the old one out. Luckily did not occur in my hand.
  11. steelflex
    steelflex Member
    Rosenberg Texas
    72 Comet GT
  12. scooper77515
    Thanks for the Autokrafters idea...I really need new light housings AND bulb holders. My housings have all warped and no longer hold everything in like they should.
