I need an ignition cylinder to fit this column
Discussion in 'General Maverick/Comet' started by John Holden, Dec 18, 2012.
  1. John Holden
    John Holden Member
    NJ
    Aparently there are different ignition cylinders through the years. I changed over to a floor shift column in my 72 and I don't know what year the new column came out of but the ignition cylinder I have doesn't fit. Can anybody tell me what year cylinder I need? Here's a picture of the column: http://robbinsvillehotrods.com/simplemachinesforum/MGalleryItem.php?id=5993
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Aside from the 70 (I can't speak for that one) there are only two different cylinders. I forget the cutoff, but I think it changed in 74. I say this because I believe I used a 73 cylinder in my 71 column. I just confirmed this on Advance Auto Part's website, assuming their info is correct.
  3. Craig Selvey
    If you want a used set-up, I would have a set with matching door locks. Email me DIRECTLY (see below) if I can help.
  4. John Holden
    John Holden Member
    NJ
    Thanks Matt, I assume 70 is the one with the key on the dash? And assuming you're correct, do I have an early or late column in mine?
    Craig, I would just need the ignition cylinder, I can key it myself. Are the door and trunk cylinders the same for all years?
  5. John Holden
    John Holden Member
    NJ
    Where is the part number? it's all together and in the car already.
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    you should be able to tell the years of the column you have by the plug for the turn signals that came with it.
    The plug for the 70-72(excluding the 69.5 with the dash mounted keyswitch) uses a different plug then the 1973 and up.
    Knowing this where your car is a 72 and the factory plug from the column plugs directly into your cars wiring harness, then your column is a 70-72 column and that is what you need to find a lock cylinder for.
    If the factory turn signal plug does not match your wiring harness then you have the later style steering column and you need to find a keyswitch for the 73 and up column. The plugs are completely different, they wont even attempt to go together, different style pins and everything so it is completely obvious if it is the wrong year turn signal plug.
  7. John Holden
    John Holden Member
    NJ
    Markso, I bought and installed a new turn signal switch so I don't know what it had originally.
  8. Joe Dirt
    The switches i guess changed mid production year 73 i just went through this trying to change the cylinder in mine
  9. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I remember just recently reading a thread on here that described which style of notch went to what year. It was within the last month I could swear.
  10. WinterBlue71
    SC
    69.5's had the dash mounted cylinder. 70''s had a column mounted switch. Mine has that.
  11. Craig Selvey
    The doors are all the same. The trunks are all the same. The door and trunk keys are different from each other.
  12. John Holden
    John Holden Member
    NJ
    So this is all good information. I still need to know what style or year cylinder I need for this column though.
  13. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Their are many to choose from depending on the year an make of car it came from.Here are some # with the years.us-62L for70-76 fairlane/torino/ltd2. from 1973-76,us68L. from 1976-79 use us-70L all are std ignition parts.
  14. John Holden
    John Holden Member
    NJ
    Which one fits my column based on the picture in the first post???????
  15. Krazy Comet
    Yeah the OP started it & I posted pictures, but what do I know???
