I installed a brand new distributor into my 1974 ford maverick 250 v6. I'm almost positive I put everything in correctly and back the way I saw it but my car won't start!!!
Top Dead CENTER. You watch the intake valve open on number 1 cylinder and you should be close. Look for the marks on the damper the front pulleys bolt to on the crankshaft. wes
Tdc= top dead center. Follow the instuctions in this video, its for a sbc but the concept is the same for all engines. https://www.youtube.com/watch?v=FHX1yXVyIMg
it's not working... I took the spark plug out and crank until I felt pressure then I put the distributor back on set it to the "1" put all the stuff back together and nothing... Well it wasn't exactly nothing... The engine is firing... But it won't stay on
Also, make sure all the spark plug wires really are where they need to be. You cross a couple of them and it will try to start but not run.
it's finally going!!!! I'm so happy... I had my girlfriends dad come help me and he said that my timing was off just a little bit, I had no idea how to do it correctly but I appreciate the help
