i NEED to know! asap
Discussion in 'General Maverick/Comet' started by MAVNWOT, Apr 21, 2005.
  1. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    1972 Ford Maverick, 302 w/ B&M tranny, everything else is stock
    hey, i am considering on swapping a 429 c.i. engine, and dropping it into my 302 maverick....and i was wondering if you guys would be kind enough to tell me EVERYTHING that i need to complete the swap!! thanks
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    To my knowledge, only Robert Raney has done this swap and his puter is down.
    Dan
  3. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    what is his s/n on here?
  4. RabidCustoms
    everything?..... lots of time and money you may or may not already know, they wont just drop in,... the shock towers must come out, thats your 1st hurdle, so think mustang 2 type front end or some other custom deal . past that, the usual expenses with swapping a motor,... and dont forget about having to make mounts,...and exhaust,....and...
    good luck on it
  5. RabidCustoms
    yeah, what he said too:evilsmile
  6. Dan Starnes
    West Central IL
    Robert is known by Robert Raney on here. He is MCCI MO state rep. Like I said, his puter is down, cant get hold of him. I went by his place of work the other nite but he wasnt around.
    Dan
  7. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    My opinion the 429 isn't a good engine. That engine had lots of problems & parts are hard to find. Better choice if you want a big block is the 460. Edelbrock has good heads for this engine. Lots of parts available. :2cents: :2cents:
  8. RabidCustoms
    I must be missing something,.... they are the same motor, both 385 series engines, just a different stroke
  9. just1993
    just1993 Mike
    Zionsville, PA
    My mistake I was thinking of the 428.
  10. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    is the frame the same for mustang and mavericks?
  11. 74merc
    74merc computer nerd
    1974 Comet
    not really. Similar, but not the same. Mavericks have more in common with 64 1/2 and 65 Mustangs as far as the engine compartment goes...
  12. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    would i need to put in a different transmission? since i have a c4?
  13. Jamie Miles
    For 429, definately. C6 if you want to stick with an automatic. Good luck getting it to fit!
  14. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You must convert the front suspension you can a kit from
    http://www.rcmotorsports.net/
    I have a Complete (less carb) 429 and a C6 for $400 you pick it up
    just1993 nothing wrong with the 428 either they had some valvetrain stability issues that are easily resolved much like the legendary 427 both are in the FE family of engines.
  15. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    does it run?? cause i would buy it, if u were closer, but i have no way of getting it from there to here
