I need to raise my car but no luck on springs or shocks that will
Discussion in 'General Maverick/Comet' started by bLaH_hA, Mar 12, 2010.
  1. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    all the shocks and springs i have found either they are stock height or lowering. i need to to be about 2" or 3" my tire is getting cut by my rear quarter panel's top. i have 15 225 8.5 then 9 in the back. And if i upgrade to a mustangII front end will i need to but front shocks for a mustang or a maverick?
  2. maverick75
    Can you post pics?
  3. 71gold
    what is the back spacing on these 9"...and what rim is 9"??? it depends on the MII kit you get...:yup:
  4. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    i am not sure about the back spacing i am pretty sure 4 as the backspacing but they are 15x9 are in the back
  5. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
  6. 71gold
    you need to check your back spacing...i am running 275x15 on the back with no rub problems...
    this is what i unloaded from my Mav when i got home from a 10 day, 3,300
    mile trip to the Gathering/Roundup...:yup:
  7. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    how do i check the backspacing? i am newbie when it comes to tires and suspension
  8. 71gold
    lay one of the wheels face down, put a straight edge across the rim (not the tire), measure down from the straight edge to the mounting surface of the wheel...(where the rim meets the brake drum).
    ...Frank
  9. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    oh alright. just curious how did you like the pictures of my maverick. i got it for $3000. everything is how it was when i bought it in june besides audio. i even got the extra fenders to replace the front ones that are dented and a heavy fiberglass grabber hood but i am not going to put non of it on until i fix the performance part and have money for a paint job. Also i have the orginal block that it came with.
  10. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Hard to tell from the pics, but it looks like your tires are sticking out past the wheel well a good 2-3 inches. You would have to have the rear dang near solid mounted or jacked sky high to keep from rubbing the tires like that. It would be safer and cheaper to just get a set of wheels with the proper backspace so that the tires don't stick out like that.....
  11. scooper77515
    Swap out the rims. Easy fix.
  12. justin has a 74
    kentucky
    i have some shackles on my car right now but my shocks are extended to a limit, shock extenders for tomorrow, then no more rubbing!!!
  13. 71gold
    you are joking?...:huh:
    ...:rofl2:...
  14. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    For the back wheels ,you could try getting your fenders rolled. that may stop the rubbing problem.
    On my car I raised the back end by adding two leaf springs on both sides, I used Monrow Reflex shocks, they are longer and bigger than the stock shocks.
    They told me they are ford Ranger shocks.
    Rasing the car gave me more of an aggressive rake, I don't really know what it does for the handling of the car. I like the stance that it gives.
    The back end is rigid and there is no rub. even when I have all the family in it.
  15. CaptainComet
    Just looking at the pic of the rear tire and the spring tells me the rim is the problem here. You have more space between the tire and the rear spring than I think I have ever seen on a Mav.
    I am running 265/50/15s and mine will very lightly rub the inner wheelhouse (above the spring) if the car goes up an angled driveway. Not even close to the outer part of the wheelwell.
