IDing a small block
Discussion in 'Technical' started by richk, Aug 19, 2004.
  1. richk
    richk Member
    I was given a small block along with a C4 trans and I'm trying to identify the engine. A bit hard since it has 40-60 lbs of oil - crud on it. One valve cover was off and I found 302 cast in the head. Couldn't find any casting mark for 2V or 4V but it came with a 2 barrel. Valve cover has a decal and I didn't find any metal tags so I'm guessing (right now) that it's 73 or later motor.
    Where do I scrap off the crud to find casting marks for the block etc? Don't really want to get into a major cleaning session right now just want to identify what I have so I can make a plan. Any recommended site that would have the info?
    The only OHV Fords I've worked on were Y-Blocks so these motors are totally new to me.
    Thanks guys;
    RichK
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    right below the head near where the starter bolts on should be the casting numbers
