If it were a money is no object type thing.... Build Your Dream Maverick
Discussion in 'General Maverick/Comet' started by DaMadman, Dec 8, 2008.
  1. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    Ok I've been a member here for quite awhile. Not as long as some but longer then most and I don't recall ever seeing this thread.
    If Money were no object and you had all the tools and know how to do it yourself or could pay anyone to do it for you tell me how you would build your Dream Maverick.....
    Here goes mine but of course I would still always have 2.. one to drive daily and then this dream car to take to the track and to car shows.
    Starting in the front I would have all the front steering and suspension redone with urethane bushing and top of the line steering and suspension parts. I think I would keep the power steering. OR a Mustang II front supsension would be really nice but not neccesary.
    at least front disc brakes, 4 wheel discs whould be extra nice
    either a Carbon Fiber Maverick Man Grabber Hood or a flat Maverick hood with a cobra jet hood scoop with the turn signals in the back.
    347 Stroker Motor putting out 400- 450 HP
    Back that up by a 4 or 5 speed tranny with a nice Hurst shifter
    Set of those JC Whitney 4 leaf springs to set the stance in the rear and 1 coil cut out of a set of new front coil springs
    Rear End would be a Detroit AIR LOCKER so I could manually lock it in and out. with a set of 3.73:1 or 3.80:1 gears
    P245 or 255 60 14's on the rear (drag Radials or DOT slicks) and 215 70's on the front Mounted on the GT Rims I currently have after they are stripped down and chromed
    Custom Dual exhaust with cutouts. Straight pipe all the way to the rear of the car capped off with dual old skewl super trapp racing mufflers.
    Interior would be a set of custom covered 1988 lowback bucket seat out of a Bronco II or a nicely recovered set of LDO Buckets. and otherwise stock Grabber interior.... WITH A/C...Cant decide on the color because I don't know what color I would want the exterior.
    Has to have a kick a$$ stereo system
    Could go with a Black exterior with white or silver stripes or ghost flames with the White interior.
    Could go with the old favorite stand-by and go with a Blue with black scoop or white or silver stripes... white interior
    Classic Bright red with Black stripes and Black and red interior
    two other combinations for appearance. Woudl be the Sprint colors with Bucket Seats like Mavaholics or a Red and Black small bumper Stallion style paint scheme with the red and black interior.
    and that my friends is the base for my Dream Maverick
    How would you build yours?????? :thumbs2::drive:
    edited to add.... Almost forgot, a Chin spoiler and a set of rear window louvers, and maybe a Mach 1 type spoiler on the rear deck lid
  2. Mavman72
    My dream Maverick would be a 70 hemi cuda 4 spd convertible.(If$$ were no object)
    but since were talkin mavericks/comets.M-II front end, rack/pinion steering.Power of course.427 side oiler w dual quads(ala shelby cobra)6 speed tremec, headers of course...3" duals with X pipe.4 link rear suspension with 9" chunk...Mini tub for 12" wide tires on 16" steelies with poverty caps,fronts would be same only 7" wide.Interrior would be factory buckets and pretty much stock other than the instruments and the wood shelby style 3 spoke steering wheel.Body would be stock with a Grabber spoiler and raised center section grabber hood(for carb clearance)Not a scoop or cowl just a massaged grabber hood with more room under it.Body color would be either a lime gold color or a candy copper color of some sort.ghosted grabber stripe down the side and ghost le-mans stripes down the hood/roof/rear deck (ala shelby) I should point out that the wheels would be body color and the interrior would be colored to complement the body.A/C nah... stereo.nah... A lumpy snarling 472 FE would be my music and the speed would be my A/C.I could go on but my wife keeps saying I have to work in the morning so... nite nite...
  3. Jamie Miles
    I'd take my '74 Grabber, put a tube chassis under it with Mustang II front suspension and 4 link rear suspension, obviously plenty of room for beefy wheel and tires, twin turbo Ford GT engine, I think a 5 speed trans would be sufficient, put small bumpers on it, Grabber hood and spoiler, all black high back bucket interior, then repaint the exterior back to it's original color scheme, which was identical to this.
    I don't know what wheels I would put on it.
    Then, since money is no issue, my dad and I would drive it down to Florida and buy his old Comet back.
  4. white trash
    white trash Member
    Leland, NC
    1969 1/2 Maverick 6cyl auto field find junker
    Mine would be all stock appearing with a DOHC 4.6 supercharged and a 6 speed. All modern suspension and brakes. And of course nice cold AC! Wide steel wheels with stock hubcaps to complete the ultimate sleeper. As far as color, I would go with a stock color (Grabber blue) and stock interior (blue) with a bench seat. I would try to make it look as stock as possible with all the go fast, stop fast and handling goodies possible.
  5. PaulS
    Well if I was going to build a "money is no object" Maverick:
    Start with a Low profile tube racing chassis.
    Formula type four wheel independent suspension.
    Carbon fiber chopped and sectioned Maverick Grabber body that opens front and rear
    A mid-engine 460 based 550 stroker with a blower
    C6 based Transaxle
    30 series tires and 14" wide wheels rated for 250+ mph
    Four wheel disk brakes with dual master cylinders on a bias rod
    Goals:
    250+ mph
    1+ Gs on the skidpad
    0 - 100 in under 7 seconds
  6. 19BlacK77
    19BlacK77 Member
    Two words...... Chip Foose! :thumbs2:
  7. rayzorsharp
    Ditto! (y)
  8. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    Probably a '70 Maverick with a 5.4 supercharged Cobra motor. Full modern suspension, a/c and heat. And just daily drive the hell out of it.
  9. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    i'm planning on a 289 with 300 HP. the guy i got the car from was gonna put it in the maverick but he said i can buy it from him since he doesn't need it. its balanced and blueprinted with lots of goodies!!!:thumbs2::chirp:
  10. justin has a 74
    kentucky
    428 cobra with 4 banger stickers all over the car LOL grabber hood and grabber spoiler for brakes, who needs them, unless you plan on stopping
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Oh, you were talking about cars, right? :rofl2:
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    the car I would want to build, is already built......I'd just have to buy it.
  13. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    Let's see, first I would need a 427 SOHC. (Like that'll ever happen) :rofl2:
    Then shave the towers.
    Then cheater slicks.
    A tow vehicle.
    Some nice paintwork, and the end result would resemble
  14. DaMadman
    Southern MD
    Now there's some old skewl word that my ears haven't heard in a few years..."CHEATER SLICKS""" WOW!!! talk about a blast from the past....
  15. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Awwww ....Thanks John but its not for sale .:biglaugh:
