if its not one thing its another
Discussion in 'General Maverick/Comet' started by justin has a 74, Feb 2, 2010.
  1. justin has a 74
    kentucky
    I finally solved my oil leak problem today and i was headed to the junkyard, suddenly my car jerks to the right and wobbles all over the place and the tires squeel at 40 mph!!!
    Pulled over and my mavericks front tires are doing the penguin Except its the opposite
    I think i need an alignment, I didnt know it could happen so fast. i just relaced the control arm:hmmm:
  2. Joe Dirt
    so what broke?
  3. justin has a 74
    kentucky
    nothing "looks" broken, took it to the tech school and hopefully we will throw it on the rack tomorrow. Im stumped.... it must be an alignment issue.
    EDIT: i left some stuff out, i just fixed it.
  4. rthomas771
    Where did you buy your parts?
  5. justin has a 74
    kentucky
    The control arm? stock part off of the driver side when i replaced it (ball joint went bad), i had to put it back because i bent it a couple months later:mad:
  6. Mavman72
    Your wheels wont just suddenly toe out...Something let go...I dont think an alignement is going to fix it. Hope I'm wrong for your wallets sake but I think your going to be buying some parts in the very near future.Good luck...
  7. justin has a 74
    kentucky
    they may not suddenly toe out but the first 3 hours of driving today, i had noticed the steering was very loose, now keep in mind this is the first time i had driven it since i did the control arm
  8. Jamie Miles
    Alto, GA
    I've had a few
    Did you have the lower control arm off? Sounds like maybe the eccentric bolt wasn't tight enough.
  9. justin has a 74
    kentucky
    Thats what i was originally thinking! I have it torqued to 30 pounds but would that really cause the tire to kickout???
    EDIT: which one is it jamie, not tight enough or slipped completely out lol
  10. Jamie Miles
    Alto, GA
    I've had a few
    Could cause it to kick in or out depending on which way it slips.
  11. rthomas771
    Torque the lower arm pivot to 75—100 ft. lbs.
  12. justin has a 74
    kentucky
    ooo i was way off...
  13. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    Anything that causes the front wheels to bow in or out scares the hell out of me! I always think........what would have happened if that happened on the highway at 120 k/m.
  14. justin has a 74
    kentucky
    Tech school fixed it for free, the tierod was loose, they replaced it, did an alignment, and tightend the control arm bolt. Car handles like a dream:character0182::woohoo1:
  15. comrick317
    comrick317 Banned
    1976 Mercury Comet
    Well you can't beat that , that's for sure.(y)
