Ignition Help
Discussion in 'General Maverick/Comet' started by Rocketlad, Feb 28, 2013.
  1. Rocketlad
    Rocketlad Garage Warrior
    Colorado Springs, CO
    1973 Grabber
    I am having a 347 built for my mav and need a good ignition setup to go with it. I have a $500 budget but I dont want to spend money on things I really dont need. Any suggestions? Ignition box? No ignition box? Distributor? Please help! Oh and links to Summit or Jegs would be extra helpful!
  2. MavMike
    MavMike Mile High Mav
    Denver, CO
    2 '70 Mavs, 1 '71 Mav, 1 '74 Grabber
    A little off topic, but who's building your 347? I'm researching local shops for a similar job.
  3. Rocketlad
    1973 Grabber
    I'm still looking around myself, but I found a shop here in the Springs called Ace's, seems like an honest place.
  4. Mavman72
    Whats the compression ratio??
    How big is the cam??
    Is it going to require high octane fuel???
    These factors will help decide what sort of ignition system you need...
    Will you be running a power adder?? Boost/Nitrous???
  5. Rocketlad
    1973 Grabber
    Not sure the compression or cam yet, but it will run on standard pump gas, and no boost/nitrous.
  6. 71gold
    ...standard ignition system...:thumbs2:
  7. MavMike
    Denver, CO
    I think I've seen their website, let me know how things go with them. If you're not committed, you might want to give these guys a look:
    http://www.coloradoengine.com/
    Either shop could probably point you to the right ignition system based on your build.
  8. rthomas771
    X2...just stay below 6500 rpm most of the time and you'll be good
  9. Rocketlad
    1973 Grabber
  10. 71gold
  11. bmcdaniel
