Ignition won't turn car off
Discussion in 'Technical' started by Rev Ron, Jan 2, 2021.
  1. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    I have 71 Comet GT. It's been sitting in the garage a while. I've been having fun with a Corvette and getting back to it, now. I noticed the old ignition switch was not working right. The switch would not lock. I bought a new switch and installed it. Now, the car will cut on and run just fine, but won' cut off. I can turn the switch to 'Off' and even pull out the key, and it will continue to run. (I put a towel over the carb to cut it off.) I took out the new switch and installed the old switch, again. Same story. It will not cut off. What am I missing here? I've studied many of the threads on this site but do not see a similar situation.
  2. Krazy Comet
    Common problem when ign bypass contact is stuck inside solenoid. When running & ign off, remove both small wires on solenoid. If engine dies that's 99% the problem.
    BTW choking a engine till it dies is one of the worse things that can be done. Creates excessive engine wear by washing down cylinder walls with gas & diluting the oil.
    Hotrock likes this.
  3. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    Yep, that was it. It had been sitting for a while and must've gotten stuck. A few knocks on it solved the problem. Will replace just to be sure it doesn't happen again. Thanks!
  4. Craig Selvey
    Warning....the NEW ones are not the best quality.
    71gold, Hotrock and Krazy Comet like this.
  5. William623
    Orlando
    1973 ford maverick grabber
    That’s why I buy NOS ones at the car shows when I find them. Always have 2 or 3 on the shelf!
    Craig Selvey likes this.
