I know this is a pretty dumb question but what import wheels can fit on a 5 lug mav? will a 5.114 lug fit? plz help
I know 1978 Toyota pickup wheels will fit, so I assume other 2wd Toyota wheels should. I had a 78, I put 67 Mustang wheels on it, and they are the same bolt pattern as a Maverick. Only difference would be the center hole diameter, and possibly the backspacing. Some of the pickup aluminum wheels were nice.
Great link Jeff. Here is another: http://ezaccessory.com/v/vspfiles/files/bolt_pattern_threadsize_new.htm
thanks a lot for the help.. btw, does anybody if the foxbody mustang lowering springs will fit in a mav? i searched threads but all the answers just beat around the bush in the ones i read...
Front ones will fit, though you may have to get the height you want. I have stock '85 Mustang GT springs in mine, which I did cut significantly.
most nissan 5 lug, toyota car, toyota 2wd truck, mistubishi car, ford probe, and a couple other share the 5x4.5 (5x114) pattern
Aren't 260Z's 4 lug? They will fit on 4 lug Mavericks and so do the older Toyota wheels like off a Supra. Someone on the board has Supra wheels on their car and it looks pretty good. The aluminum slots I have were originally on an old Datsun 1600 Roadster and they fit well.
Yes, you're right. I am confusing things again. I learned that a while back when I was trying to find what wheels I could use on the 4 lug cars.
HAHA! Thanks, but that's not my car. I was just posting it for wheel reference. I should have said that.
I know for a fact that Nissan Wheels fit. I put a set of 09 Maxima wheels on my Mav but the centers on the front would have to be clearenced a tad. Im sure most other import wheels would be the same.
