in need of a quiet exhaust (damn noise ordnance)
Discussion in 'Technical' started by bomrat, Sep 22, 2015.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hi, i have my 74 comet 5.0L fuel injected. i have dual 2.25 exhaust with glass packs. i need to install really quiet performance exhaust. i just went through the ordeal of getting my 08 ram quiet enough to pass our local laws.
    i have to be under 60db at 30 feet... i am going to add some kind of h pipe and then change out the glass packs. any ideas?
    thanks
  2. mercgt73
    mercgt73 Member
  3. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    you can get one of those tunable mufflers. they're a little pricy but you can pass inspection and then just open them up and make it loud again :rofl2::rofl2:
    i know bbk makes a manual one (called the Varatune i think) and i know someone makes one with electric motors....
    but if you wanna just leave it quiet pretty much any turbo style muffler will do the trick. just a reminder glass packs are loud, so anything more then that will yield a significant improvement.
  4. junrai
    junrai Member
    rancho cordova ca
    what they made you change the exhaust on an 08? what was on it? something other than stock? if it was stock I wouldve gave em a middle finger and said go away its factory you cant make me change it
    since you know the db rating it sounds like you got a smartass cop that pulled you over already.
    theres NO way I could pass that for sure I prolly need twice that distance to consider passing. I have about 4 inches from header to glass pack then a right turn to come out in front of the wheels with a 3" pipe :party5: needless to say myneighbors love it when I go in and out of my court setting off anyones alarm that might be on:biglaugh:
  5. Earplug
    Earplug Member
    Brighton, Colorado
    1974 Comet
    No way you would ever be able to get under 60db! That is the same level as a normal conversation or a sewing machine. The North Little Rock ordinance says 78db - 2.5.6 Motor Vehicle and Motorcycle Sound limit.
    Crazy Larry likes this.
  6. garrettmuir1227
    Temecula,CA
    thats still really freakin low... here in cali the whole sound thing is not so strict
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    When I had a crossover installed it seems to have decreased the exhaust volume.
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Get a set of take off mufflers from a newer Mustang, they obviously flow enough for good power and are quite. There's always the Z06 mufflers, they have a loud valve that you can activate for more sound.
  9. bomrat
    bomrat Member
    well i think i figured out what i am going to do... cutoff the glasspacks, install dual 23in 4in dia resonators, dual dynomax vt mufflers, and an h pipe. that should do it.
  10. garrettmuir1227
    Temecula,CA
    That setup should be plenty quiet and flow plenty well (y)
