inline 6 200
Discussion in 'Technical' started by JD71, Nov 23, 2007.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    what can i do to make my 200 run better. it misses all the time. mostly just when its cold. it has new plugs and wires. and it jus dosent run good. any sugestions?
  2. mavmanerick
    royal city, washington
    maybe try new distributer cap, rotor etc.??
  3. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    what can help with cold starts?
  4. mavmanerick
    adjust the choke so when you push the pedal to the floor it comes on...
  5. newtoford
    newtoford Member
    New Castle Delaware
    yea what he said^^^
    sounds like a choke issue
  6. mavmanerick
    ya its the black plastic piece on the back side of the carb.. just turn it towards the drivers side to get it going.. if all else fails, just sit there for a minute and hold the throttle at around 1500 rpms till it gets warm enough..
  7. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i dont really think the choke works
  8. mavmanerick
    well then youll have to get a new choke such as a manual one or do like i have to at the moment and keep pumping the gas and starting until it stays running..
  9. newtoford
    newtoford Member
    New Castle Delaware
    even if your choke works perfect be prepared to spend a few mins letting her warm up in the mornings when its cold out anyway or it will definatly struggle like that. its not good for the engine either.
    alot of people over look the warm up in modern cars since the computer will tune the fule and timing so the engine runs normal even when its cold so they dont think they need to warm it up but you still need to wait for the internal to warm up so it lasts longer
  10. mavmanerick
    this time of year its 30 degrees in the morning so i gotta let my car warm up for a minimum of 10 min. before i leave for school..
  11. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    Maybe it is time for a carb rebuild. Most likely you have a Carter YF on there.You can get better performance and quicker starts by switching to a Duraspark dizzie if you do not have one.Start checking all possible areas for vacuum leaks. Replace rubber vacuum lines, PCV.Disconnect your fuel line to the carb and pump some gas into a glass jar and check to see the contents. Put a high quality inline filter between the fuel pump and carb.Goto Fordsix if you are not on there already.
  12. Mavaholic
    You also have points to deal with. First thing I would do is replace them and make sure they are adjusted properly. A better and quicker up grade would be to go with a Pertronix set up. Second I would go after the carb. First, get the choke working, then if it still runs like crap, get it rebuilt.
  13. Jamie Miles
    Alto, GA
    I've had a few
    I agree with Dennis, get rid of the points first and foremost, then rebuild or replace the carb if it's in as bad of shape as it sounds. I would also make sure you don't have any vacuum leaks anywhere, as that will cause the car to run bad, especially at idle.
  14. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i really think is the vacume lines cause it runs ok past idle but is horrible at idle even way after warming up.
  15. brushwacker
    brushwacker New Member
    ON, Canada
    before you do anything gap your points- 020" your car will run like crap as the point gap starts closing over time.
