Installing a Cruise Control
Discussion in 'Technical' started by 20cows, Jun 14, 2007.
  1. 20cows
    20cows Member
    West Texas
    74 Maverick
    Anybody have experience doing this on a maverick? I use ours for regular 40 mile trecks and it would make the trip a might more pleasant.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Just run a coat hanger from the throttle cable to a pair of vise grips on the dash to hold constant speed.
    Be sure to run the hanger under the brake pedal so it disengages when you hit the brakes!
    I am curious too...
    Don't really need it, but it is an interesting topic.
  3. newtoford
    newtoford Member
    New Castle Delaware
    i would think you might be able to strip what you need off a lincoln or another high end curse controll'd ford of the period. if you get into the newer stuff youd probably have alot more wiring to deal with
  4. PaulS
    There are after-market kits that use add-on parts controlled by magnets on the driveline. These are ok - they wire into the brake and clutch pedals and have all the basic controls. They are a lot easier to install than trying to adapt from another car to the Maverick.
