instrument cluster lights dont work
Discussion in 'Technical' started by lovnmymav, Dec 25, 2012.
  1. lovnmymav
    lovnmymav New Member
    Richmond,VA
    1976 Ford Maverick
    My instrument cluster lights don't work. I have installed new light switch and cleaned the circuit board but the lights still don't work. Any suggestions?
  2. Krazy Comet
    I'd suggest fuse but that's too easy...
    Does the auto shift quadrant and or ashtray lamp work??? If not you likely have a loss of power from the fuse panel... If so you probably have a PCB issue...
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    _____Fuse.
  4. 71gold
    I just changed the light switch in my Mav. the new one I bought was bad...:yup:
  5. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I had this problem with my first maverick, The fuse was good,but the circut board had a small burn out spot that needed soidored together.
