Interior Change
Discussion in 'Technical' started by ADC_72Maverick, Aug 27, 2003.
  1. ADC_72Maverick
    ADC_72Maverick Member
    Albuquerque
    Maverick
    Finished my interior and got the car running and took it for a ride today!!:cool: :p ;) :) :D ....take a look at this "slight" difference between the 2 interior pictures.
  2. ADC_72Maverick
    Albuquerque
    Maverick
    and now the after
  3. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    That looks awesome!!! way to go with that interior! would you like to redo mine?> haha
    -Todd:)
  4. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Man, what a difference!!! I bet that feels great! Congrats! :D:D
    -Corbin
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    WOW! What a difference!
    Looks real nice!
  6. courier11sec
    courier11sec Member
    Tucson, AZ
    sweet!
    That looks great!
    Would you go into detail about fitting those seats in?
    Some close up pics of the mounting location and mods would be great.
    Good job.
  7. Mavaholic
    I kinda liked the beater look better. Yea right!! Looks great!
  8. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Great job! Way to go!
  9. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Yes, details please!
    It looks like you have the same seats I am trying to install in my 76. I am having fits with the passenger side hump. Is this hump in all cars or just the bench seat versions or new models (looks like it is there for cat or muffler space)? My problem is that if I try to mount the seat at the height required to clear the hump the, the drivers seat will almost hit the steering wheel when I try to get it the same height at the passenger side. Any tips out their?
    JP
  10. ADC_72Maverick
    Albuquerque
    Maverick
    Thanks for all the compliments and for all you wondering I put up a post a while ago about the seats... there from a 87? (the first body style) Mitsubishi Eclipes, Plymouth Lasers, Eagle Talons... the tracks fit right into my 72 (just plain flat tracks) so all we had to do was drill new holes and they were done... I'll try to get some detail pics later.
  11. jpollard
    jpollard Member
    Montana
    Early cars must not have the hump on the passenger side. Will a sledge hammer fix this hump situation???? It is really screwing up my plans to mount these seats.
    JP
  12. Maverick Guy
    NE Ohio
    jpollard, from what I have read, starting in 75' they started to put catalytic converters in the Mavericks/Comets. Not all 75's had them, but all 76's and up had them . . . thus the hump in your passenger side floor pan. Ideally you need to find some bucket seat tracks off a Maverick/Comet that had catalytic converter so they tracks will match the shape of the floor pan. Otherwise it sounds like you may have to do some fabrication work. Others here may have some suggestions for you in that regard. Good luck and let us know how you make out!
    ADC_72Maverick, I would like to see some of those detail pics of the tracks that you installed. Thanks! :)
  13. Maverick Guy
    NE Ohio
    another thought
    jpollard, as I discovered last weekend the outside frame on the passenger bucket from a catalytic car is raised higher than the inside frame of the passenger seat to accomodate the hump in the floor. So, the tracks and frame are different than a pre-cat. car. I hope this helps give you a better understanding of what you are up against.
  14. jpollard
    jpollard Member
    Montana
    Cat. hump
    Ok....I am going to try something that might be a little radical...Let me know if I am crazy! I am going to try and heat the cat hump up and mold it into the shape I need to match the other side. I figure this will be the easiest route and still get the results I need. If this does not work, I am going to cut out the floor of a non-cat car and weld it in. I really dislike this hump!!! It raises my seats way to high. I am installing the exact same seats as you did. Drivers seat was not a problem.
    JP
  15. ADC_72Maverick
    Albuquerque
    Maverick
    mounting specs
    The inner front mounting pad on the frame is about 1.25" lower than the outer front, and the inner rear is about 1.5" lower than the outer rear pad. So you need spacers correspondingly thick at those inner locations (for both seats, the difference between inner and outer is the same on both sides). The other important dimensions are that the seat tracks need to be 13" from inner to outer, which the Mitsu seats have. The front mounting holes (inner and outer) are 12" from the rears, so I drilled a new hole 12" from the rear mounting holes in the Mitsu tracks. This leaves about 6" of track hanging out in space at the front of the seat, which can be trimmed off but it's no fun to cut that steel. The spacers need to be 1-1/4" and 1-1/2" square tubing about 2" - 3" long for best stability
    Some picks will come soon hopefully but I need to remount them.
    Hope this helps ask me if you have any more questions.
