Is there an easy way to find out if I have Positraction Rear end?
Discussion in 'Technical' started by marty robbins, Nov 11, 2005.
  1. marty robbins
    marty robbins Member
    Olympia, Washington
    1975 Maverick Grabber
    I was goofing around once and popped the clutch and left a old fashioned burn out in my driveway, someone was looking at the marks and said because I made one on each side that I have a posi rear end is that true, or is there an easy way to find out. Any help appreciated, it's a 75 Mav stock 302 and five lug wheels if that helps. Marty
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    To my knowledge mavericks didn't come factory equiped with a locker/posi. The dealer may have installed them. So if this original probabally not. Sometimes the peg legs (single track) will grab and spin both wheels. If you have a posi Jack the rear end up and spin the wheels,both wheels will spin in the same direction. If they spin opposite then you have an open/non posi rear end. Good Luck
    Keep on Mavericking.
    Lance
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    another way to tell......when you spin-out(peel-out...so to speak). Posi-units usually leave 2 marks ,compare to the standard which only leaves 1 mark....spin on a flat dirt surface and observe the marks....
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I was told this. Dunno if it's absolutley true in all cases.
    If you jack up both wheels off the ground, both tires should turn in the same direction.
    The wheels turn in opposite direction on non-posi's.
    Can I get a confirmation from another old fart over 40?
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Yep :D
  6. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Well, I'm over 40 and pretty sure I don't fit that other description:rolleyes:, but you is co - rect, sir.
  7. Ford_Motorheads
    Ford_Motorheads Ford Addict
    Phoenix, AZ
    1961 Falcon, 1967 Ranchero, 1969 Gran Torino GT, 1974 Ranchero GT 1976 Mustang Stallion, 1977 Mustang coupe, 1978 Mach 1, and 2 1978 Cobras
    Not over 40 (18 actually), but this is how I always knew how to do it. (y)
  8. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Jack up the car:
    Wheels turn in same direction (Posi Track)
    Wheels turn in opposite direction (Open rear)
    What would the wheels do in a limited slip rear?:confused:
    I know for a fact I don't have posi track. I replaced the 3rd member years ago with a junk yard swap. When I get a good burn out going, it'll leave 2 tracks.
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Same thing as a Posi.
    A "posi" is a limited-slip. "Posi-traction" is a Chevy term. Different manufactuers have their own brand-name for limited-slip differentials. Ford calld it "Traction-Lok". Chrysler called it "Sure-Grip". Oldsmobile called it "Anti-Spin". I think it was AMC who called it "Twin-Grip". I can't remember right now what Buick and Pontiac called theirs. Most people just use the word "Posi" as a generic name for it...
    *Edited for spelling*
  10. RabidCustoms
    I thought a "possi"(posse) was a group rounded up to go get the bad guys:biglaugh:
    sorry, had too(y)
  11. T.L.
    T.L. Banned
    Southern Colorado
    Yep, I misspelled it...Guess I better edit it...
  12. RabidCustoms
    sure, go and take all my fun away :evilsmile ......:D
  13. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    They had a burn-out contest today at the Year One Show. It was pretty funny seeing some Camaro guys looking back at their driver side rear wheel and wonder why it wasn't moving ... they were doing one wheel peels. Wonder if they thought they had a posi and just found out they didn't! :)
