is this a saftey issue?
Discussion in 'Audio' started by JD71, Jan 10, 2010.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    is this a bad idea? saftey wise? i had a power port (cig lighter without the lighter) put in a while back and it has a in line fuse. to get my back lights for my guages to work i have to take the inline fuse out an put the light wires in there and put the fuse back in. so would it be a good idea to do the same thing with my memory wire for a new stereo? thanks
  2. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Won't be a problem. Very little draw. However, for future use pick up a box of these guys. Very handy critters.
  3. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    as long as the wires are on the side of the fuse that looses power when the fuse blows
    brad:)
  4. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    thanks an wut exacty are those handy critters?? im not sure that ive seen one of those before
  5. don graham
    Electrical connection. Put the wires in and crimp down on it. Makes a good connection. alo it is reusable so you can pull the wires out. :)
    Can find at Ace, Home Depot, Loews and a lot of other places.
  6. bradleygt
    bradleygt Member
    1970 maverick
  7. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    ok thanks i think i will pick up a few of those, seems very usefull
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i power my gauge lights from that same circuit! but i soldered mine onto a new connector and plugged that back onto the fuse line ;)
  9. 71gold
    wiring problems....:yup:
  10. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Not aviation grade but Ive never had issues with em. :huh:
  11. sierra grabber
    northern nevada
    i have had lots of problems with those, some where other people had spliced in trailer lights on the pickup and one in a house where it was used to splice all the outlets to the switched one. that's why i solder them now....
  12. mojo
    Very Handy Critters
    I have also had problems with these. I won't use them anymore. I have had problems w\ those making good connection even when closing w\ pliers. And yes, I was using them on the correct gauge wire.
    Also, I wud go so far as to say never use them on a circuit that make ur car run, ign. etc. JMO:dance:
  13. monstermav
    monstermav Member
    utah
    77 maverick 4dr 351
    Those circuit clips are the worst thing to happen to automotive electronics. If you have ever found an old one on a car you bought you know what I'm talking about. You should solder and shrink wrap everything if you don't want to worry about it.
  14. darren
    I have to agree. We see lots of rotten wires with those clips. They shouldnt be used on components that see weather. I dont use them even in the car just because you dont know how good the connection is. We dont like come backs so everything gets solder and heat shrink.
    You should see what road salt does to those. Cant believe guys up here use them on trailer harnesses with our weather but lots do. Its all good though cause I get paid to cut it all off and solder it down the road.(y)
  15. smiggey
    smiggey Member
    Las Vegas
    70 Maverick, 89 F-150, 92 K1500
    yea i've had many problems with those and butt connectors too. any bit of weather and the whole wire gets cancer. solder and heat shrink is the way to go. solder doesn't take too much longer anyhow
