jumping speedo cable
Discussion in 'Technical' started by rebelgt, Nov 12, 2008.
  1. rebelgt
    rebelgt Member
    Southeast Missouri
    1972 Comet GT
    Speedometer was working fine, drove it the other morning and now it works fine to 50 mph then starts to bounce back and forth 10 mph. Anything above 50 it bounces 50 to 60 or 60 to 70mph. Any ideas?
  2. rthomas771
    You have a broken cable. Replace the inner cable. Part can be found at any auto parts store
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have had them do that when the cable was binding. If the cable is not broken, you might try lubricating it with graphite.
    I also had a damaged speedo gear (plastic one) do similar things.
