Just how interchangeable is brake line?
Discussion in 'Parts Interchange' started by Mr Nick, Aug 16, 2015.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    A few questions about it....
    Can I use it in place of tranny lines and just bend it to my cooler?
    Can I also use them and fuel lines? Or is there an actual fuel line selection at a local parts store?
    Also, any input of fuel delivery would be nice. I am building my 5.0 and was thinking electrical pump. Anybody have any input on that route and advice on how to route it
  2. Krazy Comet
    Do you mean the flexible or hard lines? Either is too small and gas/oil would no doubt attack the rubber lines...
  3. rthomas771
    If you use the correct size steel tubing and maybe re-flare and change the fittings to fit the connectors. Don't use compression fittings.
    71gold likes this.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I'm going to guess you are looking at the universal pre-flared tubing at a parts store. As long as you use the correct size you'll be fine.
  5. Craig Selvey
  6. mav1970
    Steel is steel no matter what you use it for but I believe rubber "fuel hose" is designed specifically for fuel
  7. RMiller
    Kennewick, WA
    Absolutely correct, I used fuel line in the past for oil and it just doesn't last.
  8. Mr Nick
    Grapevine, Texas
    I was talking steel lines
  9. Mr Nick
    Grapevine, Texas
    Compression fittings?
  10. rthomas771
    Compression fitting
  11. 71gold
    I don't think you can get..."brake line"... large enough for fuel/transmission lines...steel line yes...brake lines have their own flare also...:yup:
  12. RMiller
    Kennewick, WA
    Stay away from brass on steel pipe, it may work but not as intended. Most hydraulic shops witl carry steel compression fittings made for use with steel tube. It may cost more but it will seal properly and hold.
