Keyless Trunk . . .
Discussion in 'Technical' started by mashori, Feb 2, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I have a keyless entry on the car. I have one wire I can hook up to the solenoid in order to have the trunk open remotely. I have the trunk solenoid already. Just can't figure out how to connect it. The rod that goes through the latch won't turn unless there is a key in the keyhole for the trunk.
    I figure I can that rod but then I won't be able to use the key on the trunk anymore which is a shame.
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    just a thought, take the rod out an hook a switch to the key. Just dont leave your jumpers in the trunk!
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Wanted to say also,,, GREAT WRITE UP on the keyless entry!
  4. Bryant
    you may be able create a slot in the lock that will let it turn.
  5. soooulpower
    Mapleton Depot, Pennsylvania
    What do you mean? I've been mulling over this same dilemma myself for a little while.
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I think he means that you can cut a slot into the long metal rod that allows it to be turned without the key in place. He's gonna show me on my trunk and I'll post it.
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Not sure if you understood my thought,,, put a electrical switch on the key end and hook your solenoid to lock mechanism. wireless unlock, hit the key send juice to solenoid an unlock,,, seems like a win win as long as your battery is up
  8. Thack
    Thack vision advicator
    Moreno Valley Ca
    I have keyed and keyless on tangerine dream. I used a 78 thunderbird trunk lock, with minor sheet metal mods
  9. soooulpower
    Any pics or whatever would be appreciated. :tiphat:
  10. soooulpower
    Isn't there a tech article on this somewhere? Wouldn't you need the thunderbird trunk key after that change?
  11. maverick75
    you mean this one that i wrote(y)
    http://mmb.maverick.to/showthread.php?t=44317
    and the stock lock works with the T-Bird latch:)
  12. Bryant
    i was thinking of notching the key cylinder that the flat bar goes into. that way the flat bar can twist to the unloc postion. today we looked at mo's lock cylinder and it may be possible but not streight forward. sounds like geting the t-bird mechanism is the way to go. sounds like a trip to the salavage yard is going to be soon.
  13. soooulpower
    That's the very one! After rereading it I see how the lock doesn't change.... I think.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    guys is this the right wiring diagram to use? I am trying to activate the power lock through a signal from my keyless remote which has a button for the trunk release:
  15. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    If the #3 circuit grounds when activated, you're all set.
