leaf spring bolt size
Discussion in 'Technical' started by zeotide, May 16, 2007.
  1. zeotide
    zeotide Member
    Does anyone know what the sizes are for the leaf spring U-bolts and eye bolts?
    I can't get a good measurement on the car and I don't want to even try to remove them until I have new ones.
    '73 2dr, 250I6. 5 lug, 8 inch rear end.
    thanks
  2. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    I got all my rear suspension hardware from ESPO. Check it out -
    http://www.espo.com/ - Hope this helps.
  3. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Got mine from AutoKrafters. Rear spring U-bolts with nuts are part# C9ZZ-5705A and are $7.50 each. Shackle kits with rubber bushings are part# FS772 and are $24.95 per side. Worked great! :thumbs2: I have a 1971 250I6 and just dropped in a 5-lug 8 inch Granada rear end.
